Old 12-23-2012, 09:07 AM
jbmuzic jbmuzic is offline
Default Can't Install Virtual Instruments
Hi all,
I am trying to install Pro Tools 10 on my system and am running into a problem when trying to install the virtual instruments package. Installation of Pro Tools went smoothly, but when I try to install the virtual instruments it begins installation and then pops up with message telling me to "Please insert the disk: 1". I tried and re-inserting the main installation disk as well as the other two disks, "Drivers" and "Audio Loops." I also tried accessing the virtual instruments installation directly from the disk, rather than the autorun menu. One installer, "Avid Virtual Instruments", claimed that "The program is already installed on your system" and wouldn't continue. The other, "Virtual Instruments Setup", tried to update the Pro Tools virtual instruments but came up with the same "Insert the disk: 1" error. After checking my windows programs under control panel, there is a program called "Avid Virtual Instruments", size at 3.53 GB. I have no way of knowing if this is the complete installation, or why this would even be installed since the installation has been interrupted every time. Any help would be greatly appreciated! Thank you!
Computer -
2012 Dell XPS 8500
Windows 7 Home Premium 64-bit
Intel Core 17-3770 3rd gen CPU @ 3.40 GHz
12 GB RAM
Audio Interface -
Presonus FireStudio Mobile
Pro Tools 10
Old 12-23-2012, 10:11 AM
Default Re: Can't Install Virtual Instruments
Issue resolved! Apparently the problem was the leftover Avid Virtual Instruments program from a Pro Tools 10 demo I had installed before purchasing. I uninstalled the demo but this evidently does not remove the virtual instruments from the system without a separate uninstall. In case anyone else has this problem, here's what I did:
Uninstalled Pro Tools 10
Uninstalled Avid Virtual Instruments (leftover from Pro Tools 10 demo)
Re-installed Pro Tools 10
Installed Virtual Instruments
Everything checks out!
Computer -
2012 Dell XPS 8500
12 GB RAM
Audio Interface -
Pro Tools 10
Virtual Instruments won't install DONSLIQ Virtual Instruments 2 02-20-2014 12:19 PM
PT Express virtual instruments wont install joebejeckel Pro Tools Express on Windows 3 01-08-2014 02:19 PM
How to Install Avid Virtual Instruments Niilo Nuori Pro Tools 10 8 10-02-2013 07:58 PM
Virtual Instruments Don't Install (PT 10.3.2 - and yes, I know they're separate) Hugen macOS 2 11-08-2012 09:17 PM
How do you un-install The virtual instruments? Psychonaut4 macOS 0 10-23-2011 04:28 PM
