Old 10-15-2002, 01:08 PM
Sabe Sabe is offline
Default WinXP problems with the "pencil tool"...
Hi DUC,
I have recently tried to use the "pencil tool" to edit a waveform. I wanted to remove a click/pop noise from a region. This is the first time I have needed this tool and to my dismay it didn't work/function properly. I zoomed in to the sample level, selected the "pencil tool" and left clicked/dragged the pencil across the waveform...nothing happened..?
I have tried several different sessions, created new sessions, called Digi Tech Support (which cost me $30.00 @ $3.00per/minute and no solution, except maybe they logged it into thier database), reinstalled ProTools, deleted ProTools preference files and nothing seems to help.
Does anybody else using WinXP experience this..? Any solutions or different paths to debug will be most appreciated.
Thanks in advance.
My system:
Intel Pentium III 866
Asus P3B-F motherboard
440bx AGPset
WD 40gig system drive
WD 40gig audio drive
Asus CD player
Adaptec SCSI card
LaCie SCSI CD burner
Microsoft (Pro) keyboard
Microsoft (Intellimouse) mouse
Matrox G400 dual video card
Soundblaster 5.1 Live sound card
Lynksys network card
..besides WinXP and ProTools, the only other software installed is WaveLAB 3.0
~Sabe
Old 10-15-2002, 01:20 PM
nightshade crisis nightshade crisis is offline
Default Re: WinXP problems with the "pencil tool"...
yeah, that same thing happened to me....i couldnt use the pencil tool, it makes ya wonder................evan
Old 10-15-2002, 01:23 PM
Hi nightshade crisis,
Are you still unable to use the "pencil tool"..? Or did you find a solution..? Are you on WinXP..?
Would you mind listing your PC specs, maybe we can find some common entity that is causing this [img]images/icons/smile.gif[/img]
Thanks for your reply, I feel better now that I am not alone (I do, however feel bad you are experiencing this too).
~Sabe
Old 10-15-2002, 01:32 PM
blueroom blueroom is offline
hi,
you may want to zoom until the pencil appear darker than when you first selected it.
Old 10-15-2002, 01:42 PM
Originally posted by blueroom:
hi,
<font size="2" face="Verdana, Arial">Hi blueroom,
Could you elaborate on that a little bit please. Do you mean to say it will only work at a particular "zoom" level (until the tool turns darker..?). I ask this because in Win98se the "zoom" level didn't matter as long as you were "zoomed" beyond the sample level.
Are you using WinXP? Have you experienced this problem too in WinXP and that fixed it..?
Thank you for your previous reply, but I guess I need some clarification if you would kindly reply again. Thanks so much [img]images/icons/smile.gif[/img]
~Sabe
Old 10-15-2002, 01:59 PM
hi sabe,
i haven't tried this with 98se...but with xp this is the only way i've found it to work.
and yes, i had the same problem regarding pencil tool.
as you've mentioned above,the zoom level seems to be the solution.
thanx,
John
Old 10-15-2002, 05:40 PM
yeah, i use windows xp home version. here are my specs
dell dimension 4550 computer
Pentium IV processor
1.8 ghz.
(400mhz system bus)
40 Gig hard drive
512 megs RAM
quietkey mouse and keyboard
24x cd rom drive........
audiomedia III card w/ pt. 5.3.1
evan
Old 10-15-2002, 06:14 PM
git1song git1song is offline
Keep expanding the wave until it becomes a line. Grab the pencil and draw away.
Old 10-15-2002, 06:38 PM
git1song, yep, already doing that (I believe they call it the sample level). I used this in Win98se without problems so I am pretty sure I am doing this correctly.
There is a definite problem here with this function on my PC and evidently a few others too. Even from a fresh install I can not use the "pencil edit" tool.
..still hoping to hear more ideas for things to try [img]images/icons/smile.gif[/img]
~Sabe
Old 10-15-2002, 07:57 PM
~Sabe,
if you are you using the pencil to redraw wave forms, increasing the zoom level is the only workaround i know of with my xp setup.
but if you are redrawing volume,mute,and pan, zoom level isn't the issue.
just curious, is your track view set to waveform?
for the record;
amd thunderbird 133
epox 8k7a
512 ddr
maxtor 30g
maxtor 40g
plextor12/10/32a
toshiba dvd
matrox dh g450 agp
winxp pro
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Audible "Tick" at Clip Gain Pencil Points? lowlights Windows 1 09-25-2012 02:25 PM
2 Problems after Upgrade PT9 to PT10: "Controller-Personality MBox3" and "MP3.dll" Eviltubbie Windows 5 07-03-2012 10:39 AM
Pro-Tool 9.0.3 "Critical Update" Problems martinaston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-20-2011 12:10 PM
Using the "Pencil Tool" question Sabe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-10-2002 09:16 PM
