Old 03-31-2021, 09:26 AM
sw rec sw rec is offline
Default Constant screen freezing
Win 10 latest HD update, PT 2021.3. Nvidia quadro fx 1800 video card.
This constant screen freezing is unacceptable. It’s about every 10-15 seconds, and freezes for at least 5 seconds. I can’t get anything done this way. Missing some setting somewhere, maybe? It even does it while it’s “idling.” Watch the position cursor flash, then it’ll freeze for about 5 seconds. (2020.3 did it once in awhile, with a Matrox card in place, but this does it ALL THE DANG TIME, even with an approved card and latest drivers.) It also does not do it on any other programs. What am I missing here? Tired of it!
Old 03-31-2021, 09:44 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Constant screen freezing
Can you try a new cable? If it's not the cable, can you try a different monitor? I had my Dell UltraSharp start to go after 6 years of faithful service. I got squiggly white lines along the bottom across the Taskbar off and on.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-31-2021, 09:48 AM
Brand new cables (the cat DIDN’T eat these. True story). The screen isn’t flashing or creating any artifacts, and in fact, if put the edit window on the left monitor, and the mix window on the right monitor, it still does it. Funny, an old instance of 10.3 on an even older MAC at my freelance gig doesn’t act up at all.
Old 03-31-2021, 09:51 AM
Tried a few things....OPERATION: both enable and disable gpu, both prevent tearing, and not prevent tearing, same thing.
Perplexing.
Old 03-31-2021, 12:25 PM
Nvidia just released a new driver. Will let you know if that helps. And wondering if perchance screen resolution comes into play with this?
Old 03-31-2021, 06:14 PM
Update, aka “stuff I never thought about.” Windows update enabled “disk indexing.” Unchecked it on all drives and it seems to be behaving a lot better.
Old 04-01-2021, 08:05 AM
Those pesky updates...........you probably should check a few other settings too as Windows updates have(sometimes) changed USB Power Management and the "default playback device" Glad you have it under control
Old 04-01-2021, 08:17 AM
Funny, after every update, that’s exactly what I do...check USB power management, playback devices, look to see if it pushed my UA OCTO card out of the way....disk indexing never occurred to me until yesterday. It also screwed with some of my network drive mapping. ”That way I learn!”
Constant freezing and lag of whole PC nkproduction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-31-2010 12:28 PM
OSX Constant Screen Resizing is Driving Me NUTS!!! MissHiss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-10-2006 03:39 PM
HELP !!!CONSTANT BLUE SCREEN STOP ERROR:0X0000000A E. LONDON 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-22-2006 10:23 PM
Help!! Constant SCREEN FREEZES and Out of the Blue SYSTEM REBOOTS ITSELF! asher400 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-07-2003 10:15 AM
g4 dual, 9.04, pt 5.01 constant freezing, please advise. tomcat Pro Tools TDM Systems (Mac) 0 09-09-2000 04:59 PM
