Re Amp setup
Hello
Total newbie here. I'm trying to Re Amp using the Eleven Rack and ProTools10. I've set the Rig Input in the Eleven Editor to Re Amp, but I can't seem to find anything labeled on any of the output choices in Pro Tools. What am I missing? Thanks in advance |
Re: Re Amp setup
UPDATE:
I imported the Eleven Rack IO settings into my PT session, but still can't generate anything on the clean DI track |
Re: Re Amp setup
Anyone??
Re: Re Amp setup
Re: Re Amp setup
The names in Pro Tools IO paths don't actually mean anything, but if you want to see the standard names then... always double check the Eleven Rack is selected as the playback engine (yes Pro Tools will pick something else when you least expect it to). Then go to Setup>IO and on each of the Input, Output and Bus pages click on any IOs, click delete to remove them all, then click the default button. You'll now see the standard Eleven Rack IO names for input and outputs.
To make it easy for the first time also start by creating a session using one of the Eleven Rack standard session templates that include reamping. |
Re: Re Amp setup
Thanks so much! I'll give it a try. It's been very frustrating
Re: Re Amp setup
GRRRRRR!
Still not working. I checked the iO settings in PT and they seem ok. I also imported the session template for the Eleven Rack tracking and reamping and still nothing I tried to attach a pic of my user settings. Maybe I have something set incorrectly. |
Re: Re Amp setup
Focus the camera then post another shot.
Did. You default the io settings? How's the 11r connected ?
Re: Re Amp setup
I didn't exactly ask you to check anything if they looked OK, I asked you to delete and default the settings. If they are listed on the IO pages then they will appear as options in the track input and output IO... which is what you were complaining about not being there. So what options exactly show up for the track IO input and output selectors?... post a screenshot of that.
I've given you exact things to do? Did you do every exact things. Post screenshots (please not photos) of the IO pages you defaulted, of the Playback engine dialog page, and the mix window showing tracks you are trying to reamp from and to, clearly showing their IO assignments. I asked you to start a new session from a template with reamp, not import a template. I'm asking you to to exact things, please just do them. And answer all questions asked. |
Re: Re Amp setup
As Darryl said you really need to start a blank session and default the IO. Don't use a template, in my experience they are set up wrong for the Eleven Rack.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
I/0 setup weirdness, sessions overwrite my setup | digidesigner | Pro Tools TDM Systems (Win) | 0 | 10-20-2011 11:40 AM |
PT 9 setup problem..Where are the MIDI IN options in setup menu?? | Blickerding | Windows | 0 | 04-06-2011 02:44 PM |
I/O setup doesn't reflect my hardware setup | devapro | Pro Tools TDM Systems (Mac) | 7 | 12-30-2006 11:16 AM |
"Edit MIDI Setup" Setup Menu Item is Missing! | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-08-2004 12:24 PM |
