Old 02-28-2024, 04:24 PM
aliclk aliclk is offline
Default Mixing tracks as fake stereo. Is this a fault?
Hello everyone! I'm new to the community, so I apologize in advance for any mistakes about posting a thread.
I have a project recorded six years ago in Cubase 5, and recently, I decided to mix it. Many of the tracks (channels) I originally recorded in mono were exported by Cubase 5 as fake stereo. Despite this, I moved the project to Pro Tools for mixing. I processed several channels, including bass guitar, electric guitar, and acoustic guitar. However, when I reached the vocals, I realized I had been working in stereo until now (a bit late, I know). More importantly, I ran most signals, including vocals, through iZotope RX and Melodyne (working as standalone), obtaining fake stereo signals and then mixing them again.
My question is whether it's wrong to mix these originally mono signals as fake stereo. If so, how can I convert these channels back to mono without losing my mix (the split into mono method seems unnecessary)?
Has anyone intentionally worked with mono channels as fake stereo? If so, why did you choose this method, or why shouldn't it be preferred?
This project is for my thesis, and that's why I'm putting so much thought into it.
Old 02-28-2024, 04:51 PM
Default Re: Mixing tracks as fake stereo. Is this a fault?
Welcome aboard! If by "fake stereo" you mean a track that is exactly the same on left and right(dual mono), then it will sound like a mono track. This happens a lot with audio files from Logic and GarageBand. My preference is to use the "Split to Mono" option and keep one mono track, then hide(make inactive) or delete the other mono and original "stereo" tracks, just to keep the session tidy. Even after your Melodyne and RX work, if you committed those, you can probably do as I described above(split and delete what you don't need). This is assuming there was no actual stereo effect added to the audio file. There really is no "problem" with treating(mixing) those tracks just as you would with a mono track, except that it might cause you to mix too hot(a fake stereo track will sum a bit hotter than a mono track).
As this is for your thesis, will the session be looked at? If yes, then I would probably do a lot of "housecleaning" before handing it over. I would split to mono(this will require you to redo your panning) and clean out all the "garbage". I would also rename tracks AND audio files so things are neat and clear(tracks that are chopped up into lots of smaller clips would get consolidated before the file renaming). when I do this(consolidate and rename), I often duplicate the Playlist first and then consolidate the duplicate(leaving the original chopped up track hidden away, but still available, just in case....)
Old 02-28-2024, 04:54 PM
_JJ_ _JJ_ is offline
Sorry I don't quite understand what you mean by "fake stereo" but if you like the sound of your mix then don't change it now because of some perceived rule. There kinda are no rules.
I do know that many DAWs export mono tracks as stereo tracks for some reason. And there's a great app called StereoMonoizer which can tell you if an interleaved audio file has any stereo content or is indeed dual-mono. If it's not really stereo you can split the track in PT, delete one side, and work with it as a mono track.
(albee beat me to it with a better answer...)
2023 MacBook Pro 15,8 (M3 max)
Mac OS 14.4 (Sonoma)
PT 24.3.1.162 (Ultimate)
TB Native + Omni at home
Apogee Duet 3 on the road
Old 02-28-2024, 04:57 PM
^^^ and if that is not it. Do you have the original Cubase 5 sessions? If so why not go back to them and output the mono tracks as mono. You can get a free trial of Cubase if needed.
Old 02-28-2024, 05:41 PM
Split into mono was the first method that came to my mind as well, but I was afraid of losing data from the original mono signal this way. Because Cubase converted a lossless mono signal into a lossless stereo signal. Wouldn't cutting one side of this signal result in data loss? By the way, thank you very much for your interest.
Sorry about that I mean dual mono. I tried the Split into Mono method, and there is a 2 dB drop on the VU meter. Actually, this is not too significant, but I am concerned about experiencing other losses when using only one side of the signal (for example, a lower-quality signal that I may not recognize with my hardware). Thank you for your reply. The mix sounds good in its current state btw.
I have the original session actually. The problem is I already processed those signals with RX and Melodyne while working standalone. Thank you for advice.
Old 02-28-2024, 07:51 PM
smurfyou smurfyou is offline
No you will not lose quality if you split into Mono.
It is not a "fault" to do this, just a hassle. For instance panning.
But if you have a mix as you like it, just leave it. Not hurting anything.
~Will
Old 02-29-2024, 03:31 AM
Okay thank you so much.
Old 02-29-2024, 08:15 AM
...there's a great app called StereoMonoizer which can tell you if an interleaved audio file has any stereo content or is indeed dual-mono....
^^^^This. Anytime I get a batch of files to mix from the outside world (esp if they've come from Logic) the first thing I do is dump 'em into StereoMonoizer to check 'em - there's *always* stereo tracks with mono content.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-29-2024, 12:42 PM
I solved the issue by using only one side of the dual mono signal.
After selecting the channels that should be mono, I saved them to another location using the 'save copy in' method. For each channel, I obtained two wav files and imported one of them back into the project.
Then I performed gain staging again for each clip (using the previous settings). Afterward, I repanned all of them.
The only issue is that there's approximately a 3 dB drop when using only one side of the dual mono signal. However, this can be easily resolved.
Thank you all again for your interest.
Old 02-29-2024, 01:07 PM
JFreak's Avatar
JFreak JFreak is offline
If every track drops 3dB you only get 3dB more headroom
Janne
How to approach mixing stereo tracks Cglass1982 Avid Pro Mixing General Discussion 3 05-07-2019 10:44 AM
Stereo Fault Interleaved or split HiLoc macOS 0 01-15-2014 02:20 AM
mixing multiple tracks to a single stereo track billardis Windows 2 10-12-2013 04:36 PM
Mono to 'fake stereo'? Silent Sentinel Tips & Tricks 7 08-17-2011 08:43 AM
TRacks EQ Fault? Silent Noise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-17-2004 06:23 AM
