Old 03-11-2024, 12:33 PM
bigbuddy3 bigbuddy3 is offline
Default Avid HD I/O +4 Analog Out Calibration
HI,
I have the Most recent HD I/O- Configured as (8x8x8)
Unlike the 192's out Card card which has 16 Trim pots ( 8 for +4 and Eight for -10). The latest version Analog out card has 8 trim pots total, the manual notes that +4 is cal at the factory and the pots only work on the -10 if you move the internal jumper.
Is there any info how to adjust the +4 output, Output 1 is 4 db hotter then all other 7 channels..... I can confirm Turning trim pot is not adjusting the +4 output
Fom HD I/O manual:
"The HD I/O Analog Out card contains a single DB–25 connector and Output Trims for eight channels of analog audio output. These balanced outputs operate at +4 dBu levels.
For –10 dBV gear, you can switch a jumper on Analog Output cards (on a channel-by- channel basis) from the default Hi position to Lo for a –6 dB pad. You can then adjust the Trim pot f[/B][/B]or the corresponding output channels by an additional –4 dB to accom- modate –10 dBV gear.
Thanks!
Old 03-11-2024, 01:03 PM
Default Re: Avid HD I/O +4 Analog Out Calibration
You can confirm it with a voltmeter and a screwdriver (not the drink).
Avid Pro Tools HD I/O 16x16 Analog w/ (4) Avid db25-TRS snakes-Like New-$1,875 songwritersoul Buy & Sell 0 02-02-2023 08:42 AM
AVID HD I/O 16x16 ANALOG INTERFACE + AVID HDX PCie Card + Magma Chassi Kaliber Buy & Sell 0 08-30-2020 08:44 AM
Avid Pre calibration question jbreher Pro Tools HDX & HD Native Systems (Mac) 15 10-24-2019 11:49 PM
Question for Avid Tech Support: Omni Calibration Jack Ruston UK Pro Tools TDM Systems (Mac) 5 10-07-2011 08:08 AM
Protools Calibration Mode: low analog input levels SoundReplay Pro Tools TDM Systems (Mac) 2 03-20-2006 12:38 PM
