Old 11-25-2020, 01:15 PM
nst7 nst7 is offline
Default What is frame edge sync?
I am asking this question because the new Carbon interface apparently doesn't have it. I don't know what it is to know if I should care.
Note that I have had the HD Omni and HD Native Thunderbolt for several years, I don't know if the Omni has it either (or if the thunderbolt unit has it). Just trying to figure out if what I would need it for. Or if I've had it and didn't realize it, etc.
I do some sound for video stuff as a hobby, nothing professional. When I've done surround stuff, I don't use the HD Native/Omni setup, but instead go HDMI into my Pioneer receiver and home theater setup.
Thanks in advance.
Old 11-25-2020, 03:13 PM
smurfyou smurfyou is offline
Default Re: What is frame edge sync?
It's just a way of describing the way a DAW syncs playback to a video reference signal. When locked it will always play in sync with the incoming video frames as opposed to freewheeling.
In practice it means without it you can get sync slop because every play could be offset within a frame's length. Whether that is an issue depends on your usage. Sounds like you shouldn't need to worry about it.
~Will
Old 01-05-2021, 03:12 PM
kosmokrator kosmokrator is offline
wait, there are actually people doing this as a _hobby_?
Baffled..
Old 01-05-2021, 05:54 PM
Baffled..
I'm heavily into video and love filmmaking, so the interest in surround follows that. I got the HD/Ultimate setup years ago for music purposes, then started experimenting. The only things I've done with surround so far is a couple of video productions of special Christmas services that I did for my church. I made some DVD's and Blu-rays to give to the people involved in it. Basically the equivalent of a concert video. I'm hoping at some point to do other types of live events such as plays/musicals, concerts, etc., and be able to have the option of surround for the clients. However, physical media is becoming less of a thing, and streaming services that are utilized for these types of things don't yet support surround.
Old 01-05-2021, 09:30 PM
LukeHoward LukeHoward is offline
You wouldn't have had it unless you were using a SYNC HD as (audio) clock master, locked to the same (video) reference as your video output device.
https://lukehoward.com/
Old 01-06-2021, 11:56 AM
Thank you for that information.
Is this something that would be required for ADR, especially if using a separate program like Videoslave?
HTML code is On
New Mac Pro, AJA & Frame Accurate Sync rmccam Post - Surround - Video 8 05-26-2020 11:59 AM
Frame Sync Issue PTAmateur Pro Tools TDM Systems (Mac) 7 10-08-2008 02:47 PM
Frame Sync or Frame Store - Plasma v. CRT Chief Technician Post - Surround - Video 3 10-10-2006 08:50 AM
SYNC I/O FRAME EDGE ACCURACY - Digi Please Respond grivel Post - Surround - Video 3 05-25-2004 10:38 PM
Sync and frame rate sobeauty Tips & Tricks 0 07-01-2002 08:59 PM
