Old 05-21-2010, 02:56 AM
mrbeef mrbeef is offline
Default Re-amping with Mbox Mini
I've been trying to re-amp some DI'd guitar & am experiencing nasty feedback loop problems. I was wondering if anyone has had any success with this or knows of a workaround?
Assuming track 1 is the player & track 2 is the recorder, I've tried soloing track 1 & routing it to output 1 only. Output 1 is sent to the amp, the amp is miked up & sent back into input 1, which is being looked at by track 2, which is record enabled but muted....& routed to output 2 only (which I would have thought would be irrelevant as it's muted!).
I'm running Pro Tools LE v8.0.3 & my hardware is the MBox Mini (I suspect this may be the route of my problems!). I have re-amped using before using cubase & turning off the record track's monitoring seemed to do the trick.
....I'm a little confused!
Old 05-21-2010, 03:32 AM
Default Re: Re-amping with Mbox Mini
....think I'm being a dumbass! It's an impedence problem isn't it, not a feedback loop. I was trying to add distortion to the signal, which sounded nasty. Think I'm going to need some manner of impedence matching box. Any advice on a shoe string budget?!
Old 05-21-2010, 08:04 AM
Mikeren Mikeren is offline
Connect the mic the input 2...not 1.
Learn to listen. Listen to learn.
Re-amping with an Mbox? Audio85 Eleven Rack 2 10-15-2011 12:11 AM
Downgrading MBOX 2 to MBOX mini (Quick question) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 09:29 PM
Am I Missing Something?! Mbox Mini, Mac Mini, Shockingly Bad gunark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-07-2010 01:58 PM
Mac Mini and Mbox 2 Mini Issues neilwilsonvoiceovers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-17-2010 10:34 AM
re-amping with a podxt and mbox jrm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-03-2006 03:04 PM
