Old 12-10-2016, 05:13 PM
johnnyv johnnyv is offline
Default Best way to convert Sound Designer II files to wav?
Anyone know a good way? I've got sizable amount of Sound Designer II files to convert to wav.
What is the best way here in 2016?
Thanks in advance...
Old 12-10-2016, 07:44 PM
Default Re: Best way to convert Sound Designer II files to wav?
Easiest is to open the sessions on an older system, then go File>Save Copy> and convert to wave(and Enforce PC/Mac Compatibility). I keep an old G4/Mbox for just that purpose
Old 12-10-2016, 08:10 PM
Sardi Sardi is offline
Well, you don't say if you're on a Mac or PC, so kinda hard to suggest appropriate software.
I'll assume you're on Mac, as I don't believe Windows versions of Pro Tools ever used the SDII format. With that in mind, grab a copy of Max.
http://sbooth.org/Max/#download
It's free and converts from virtually any format to another.
Make sure you download the latest unstable build (which is very stable) as you may have issues with the stable version and current versions of Mac OS. I've run it on 10.5 all the way up to 10.11 with no issues.
Old 12-11-2016, 11:54 AM
midnightrambler midnightrambler is offline
As an aside, this has got to be one of the worst things about making music in the 21st century. I know 'twas ever thus (the number of actually useable 2" tape machines are presumably decreasing by the year, for instance), but who really knows whether we'll be able to read any of our current state-of-the-art files in 20 years' time, when e.g. WAVS have been rendered obsolete by some other slightly different but superficially better format.
Old 12-11-2016, 12:17 PM
Using a file converter is fine if each track is a single file and all start together. Sadly, most sessions end up with tons of clips(regions) and gaps and getting all the converted files to land in their proper place on the timeline can be a real crapshoot. Opening on an older Mac system eliminates lots of hair pulling.
Old 12-11-2016, 12:30 PM
I hear ya Albee.
Unfortunately the OP is pretty vague on details. He may just need to convert a bunch of samples or he may need multi tracks or ??.
Asking for help with computers etc. really requires some basic info of your setup and what you're trying to achieve.
Old 12-11-2016, 01:50 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
If the SD2 file has ever been on an FTP server or a non-mac drive, the files will have been corrupted. Recent mac drives could also be a problem.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 12-11-2016, 03:56 PM
Top Jimmy's Avatar
Corrupted or just missing the resource forks?
Rail's Sd2wav converter works great as long as a person knows the sampling rate and bit depth. Haven't seen him around here in a while.
http://www.railjonrogut.com/sdTwoWav.htm
James Cadwallader
Old 12-11-2016, 05:24 PM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
This whole situation is farcical! Digidesign advised us to record our sessions with SD2 files rather than choosing the WAV option and then they drop support after all these years Now we are left scrambling looking for workarounds and solutions
Avid should at least support the importing of old SD2 Sessions and upgrading to the new standard natively, even if they don't want to continue with the option of saving as SD2.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 12-11-2016, 07:08 PM
Missing the resource forks due to corruption. You can take care of sample rate and bit depth but not the location encoding.
Avid defaulted to BWAV many years ago and Apple started warning of resource forks going away back when system 8 was released!
Interview
Will Files - Re-Recording Mixer, Sound Supervisor and Sound Designer Tom Graham Avid Pro Mixing General Discussion 0 09-08-2014 01:16 PM
Sound Designer I files scullionj Post - Surround - Video 5 07-19-2014 05:53 PM
Sound Designer 2 files pminda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-20-2005 12:51 AM
Sound Designer 2 files Bob-sw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-13-2003 12:56 AM
Sound Designer II Files and the 001? Rutles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-05-2000 06:30 PM
