Old 02-04-2019, 12:27 PM
danieleither danieleither is offline
Default UVI Falcon stuttering / freezing
I have recently upgraded to PT Ultimate (2018.12) with 1 x HDX card. It's a fresh install on High Sierra (as recommended by Avid) - OS is also a fresh install.
I've installed UVI Falcon (using the Avid download links from my Avid account). It will open, and the GUI appears to be working correctly but after hitting a few notes (via MIDI from a controller keyboard) it will stutter and freeze. The amount of notes played before this happens varies depending on the patch loaded, some patches will play absolutely fine but most cause it to stutter and freeze. It typically freezes for around 5-10 seconds and then you can play it again (although it will do the same thing). Whilst 'frozen', when hitting notes on the controller keyboard no additional sounds play, and also the GUI keyboard in the plugin stops responding as well.
I've tried mucking around with buffer settings to no avail and having skipped through the menus and options, I can't see anything obvious that would cause this. Any suggestions?
Mac Pro 5.1 (2010)
Dual 3.46GHz / 12-Core
64GB RAM
GTX 780
250GB SSD Boot drive
2 x 1TB storage (7200rpm)
Mac OS High Sierra (10.13.16)
Old 02-05-2019, 01:38 PM
Default Re: UVI Falcon stuttering / freezing
Having investigated further (basically opening the plugin and PT System Usage window at the same time) I can see that it is using 100% CPU when the stuttering / freezing occurs.
The above is in a brand new session with one single track with Falcon as a plugin.
Old 02-06-2019, 05:33 AM
K Roche's Avatar
K Roche K Roche is offline
I had the same issue (but do not remember for sure how I solved it) but I "think" it was trying to run it at 32 buffer and had to go to 128 or something
But you say you have tried changing buffer so i do not know
It is now working great, so I will check later today in the studio and see what buffer I am using
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB........PTHDN 2018.12 on OS 10.13.6 High Sierra on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2dn Samsung 970 EVO 1 TB --
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 02-06-2019, 09:31 AM
The only buffer settings I've tried are in the PT playback engine settings (I've tried all settings from 128 up to 2048 samples). Thus far I've not found any other place to adjust buffer settings.
The settings you mention - are they in PT or in Falcon itself?
Old 02-06-2019, 10:49 AM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
The buffer settings are in PT and not in Falcon.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-06-2019, 10:59 AM
K Roche's Avatar
Yes as Southside said in PT
System :
Enjoy the Journey
.... Kev...
Old 02-07-2019, 04:30 PM
Are there some settings I'm missing then? The only settings I can find that relate to the word 'buffer' are in the playback engine (settings from 128 - 2048 samples). I've tried all of these and they make no difference. As soon as you hit a few keys the CPU usage maxes out and it freezes / stutters
Old 03-29-2019, 12:56 PM
Juraj Bernáth Juraj Bernáth is offline
I have exactly the same problem. Does anyone know how to solve the problem?
MacBook Pro 2012 i7 2,6GHz, 16GB RAM, Mac OS 10.13.6, Pro Tools 2018.12, Apollo 8 DUO
Old 03-29-2019, 07:16 PM
unkJE's Avatar
unkJE unkJE is offline
UVI Falcon version 1.6.4 has been updated to version 1.6.6 – check your Avid account. Hope that fixes it!
Pro Tools 2019.6/10.3.10 and 12.5.1 HD - Studio One 4 Pro - Win7 64 Ultimate (SP1) – Lenovo W520 ThinkPads & 433830U Docks – Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
Old 04-03-2019, 01:46 AM
Great. I had v.1.6.3 Thank you.
Falcon Problem notr2d2 Virtual Instruments 5 01-05-2019 06:19 AM
Falcon - New VI from UVI DonaldM Virtual Instruments 3 11-09-2015 06:45 AM
7.4.2 ongoing issues - stuttering, freezing and more RW1965 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 07-15-2008 06:13 AM
PB G3 1999 series momentarily freezing/stuttering.... Mt.Everest Pro Tools TDM Systems (Mac) 0 04-26-2001 11:53 AM
