Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
  #31
Old 07-05-2018, 01:07 PM
Default Re: -9093 stops are killing me!!!!!
Guess I got excited too soon. -9093 is back after 1 flawless record pass for 15 minutes, now its a crapshoot. 1 minute, maybe 2, maybe 3:27, maybe......
  #32
Old 07-05-2018, 04:33 PM
Also tried the core affinity trick, and like everything else, it seems good at first, then goes south sooner than later
  #33
Old 07-24-2018, 03:18 PM
PatriotsBiker PatriotsBiker is offline
Just FYI, fellow 750TI owner, I ran the NVidia Geforce update last week a day after it came out. 7-19, IIRC. No spikes since. I also did, as always, quite a few CCleaner analysis and cleanup iterations after install, before running PT.
And that, folks, is how I jinx myself. TBD
  #34
Old 07-24-2018, 06:28 PM
Did the same here with no improvement. Out of desperation, I uninstalled 2018 and installed 12.4 but no matter what I did, PT refused to find the HDN card. (ran the HD driver install again=no dice. Double-checked Sound settings, they were correct. Held the N key while opening PT, no HDN available. Double-checked iLoks and all is as it should be. tried running PT with only single iLok with 12HD license=no luck. Another wasted day.......
  #35
Old 07-28-2018, 01:37 PM
I knew it wouldn't last. two more days. Simple swap plugs out and back into the folder took care of this one. The interface is back to clicking, though, I also had the audio lock loud buzz thing yesterday. Re-install imminent. It's been a few weeks.
  #36
Old 07-30-2018, 07:46 AM
scottgreiner scottgreiner is offline
Since you're on a PC, try running latencymon from resplendence:
http://www.resplendence.com/latencymon
With no other applications running, it will tell you what services might cause a wait-state long enough to make your DAW glitch. Anything over 500µS is likely to cause problems in your DAW.
  #37
Old 09-13-2018, 11:53 AM
pqlior@mac.com pqlior@mac.com is offline
Was excited to update to 2018/7. Waited a long time before switching from 12.8.1 and still in 9093 land. Real bummer. New features are cool, but stopping all the time for errors is NOT. (I'm on 10.12.5 Sierra)
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
  #38
Old 09-13-2018, 12:15 PM
JFreak's Avatar
JFreak JFreak is offline
How about upgrading to High Sierra?
Janne
  #39
Old 09-13-2018, 03:57 PM
Is everyone super stable in high Sierra?
Lior
  #40
Old 09-13-2018, 04:12 PM
JFreak's Avatar
At least I am
Janne
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 11:43 AM
11R killing PT thegreyfox Eleven Rack 3 04-24-2012 09:34 PM
This is KILLING me! audiogeekzine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-22-2008 04:10 PM
-9093 error's killing me!!! coryc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-04-2003 03:24 PM
-9093 Error, CPU stops rec., says buffer problem? storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-16-2003 09:33 PM
