Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
  #21
Old 10-18-2017, 11:01 AM
PT user PT user is offline
Default Re: EUCON 3.7 crashes immediately!!!!!
Ok - If I hit the launch with Eucon tab - it does actually work - despite telling me it isn't compatible
  #22
Old 10-18-2017, 11:10 AM
moranibus moranibus is offline
4 clean installs of 3.7, still crashes when opening PT.
PT Ultimate, Avid S3, Avid Artist Transport, Pro Tools Control
  #23
Old 10-18-2017, 11:21 AM
The Mixing Factory The Mixing Factory is offline
I had the same issue and after trying a few things this worked for me:
Uninstall v3.7 and trashing the folder "Euphonix" left in your applications folder (assuming you are on MacOS), install again v3.7 with all other apps closed but peripherals switched on. Open EUC and tick EUcontrol under the "Auto-launch Apps" sub menu, restart the computer (EUC should now open on boot up) and open PT.
I didn't uninstall the old version before installing v3.7 so I can only asume that was the issue.
I also got the weird message with the silly "Minimum EuCon build: 65,916" build number at startup in Logic Pro 10.3.1, I clicked on "Launch with EUcon" and seems to work fine.
All my settings/soft keys/num pad configuration are still there, no need to trash preferences...
  #24
Old 10-18-2017, 11:28 AM
Anthony_Anz Anthony_Anz is offline
Is this just happening on MAC? I am on a PC. I just upgraded PT to 12.8.2 and EuCon 3.7 and I didn't experience any crashing.
  #25
Old 10-18-2017, 11:51 AM
ripekeai ripekeai is offline
Uninstalling Eucon and deleting euphonix folder in applications, install and restart worked for me.
  #26
Old 10-18-2017, 11:52 AM
Sean Bombz Sean Bombz is offline
Mac here . Won’t be able to try clean install until Friday . Hopefully it works
Sean Bombz
Mac Pro late 2013 3.5GHZ 6 core 64g ram
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
  #27
Old 10-18-2017, 11:55 AM
EddieJones's Avatar
We'll have it fixed well before then and swap out the installer....so re-download on Friday before you install.
  #28
Old 10-18-2017, 11:56 AM
Thanks Eddie!!!
Sean Bombz
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
  #29
Old 10-18-2017, 02:22 PM
EddieJones's Avatar
We found the issue and it's not to do with the software but the installer. The workaround until we generate a new installer is to simply uninstall 3.7(or3.6) and reinstall it. No need for the Clean EUCON script.
  #30
Old 10-18-2017, 02:30 PM
Kaneepa Kaneepa is offline
Uninstalling and re-installing 3.7 still crashes EUCON all the time when PT is on..
EuControl 3.7 crashes immediately with PT moranibus Pro Tools | Control 11 10-19-2017 08:52 AM
Pro Tools crashes immediately Rich Crescenti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-21-2010 03:44 PM
PT8 M-Powered Crashes Immediately chrisconover Pro Tools M-Powered (Mac) 10 05-31-2009 10:19 PM
LE 6.4 crashes immediately with 002R j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-27-2005 06:37 AM
Mac G4 Crashes Immediately...I'm really new to this luapfitz Pro Tools TDM Systems (Mac) 2 09-04-2000 05:40 AM
