Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
  #21
Old 01-15-2018, 03:19 AM
willco willco is offline
Default Re: 10.5 iPad Pro support?
Hey Eddie - this appears on the avid store but won't add to my basket to buy it from uk - should i contact a reseller instead?
  #22
Old 01-15-2018, 11:20 AM
EddieJones's Avatar
Thanks for reporting this, I have asked the web team to fix. Please try again tomorrow. Its only available from the Web Store at the moment. Eddie
  #23
Old 04-09-2019, 07:20 PM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
just got a 10.5 iPad pro for my dock. Got the adapter. For anyone looking to do this it can be done for sure, but takes some manipulation. Once you have installed the adapter you are going to want to put the cable into the iPad before putting it in the dock, then slide the iPad into the slot at an angle to make sure the lightning connector goes under the side knob panel and thru the gap. Its really tight like a bum in a bucket. But it will insert albeit with pressure on the lightning cable. Unless I'm doing it wrong!
http://www.ainsliegrosser.com/
2013 MacPro 6 x 3.5 32GB OS10.14.4 HDX2 Sonnet Chassis, PT2019.5. Macbook 2018 Watch this to follow mobile mix studio build coming: https://youtu.be/cbqMTjCVj9I
  #24
Old 04-17-2019, 06:16 AM
robertg robertg is offline
It looks like this dock adapter isn't right with the latest redesigned ipad pro, the square one with USB-C. It kind of fits in the groove but the usb-c port is obscured by the dock completely.
Eddie
Any plans to update this adapter again? I'll have to return mine unfortunately
  #25
Old 04-17-2019, 08:44 AM
EddieJones's Avatar
Did you try with and without the rear support ? Could you post a picture ?
  #26
Old 04-17-2019, 09:01 AM
I don't use the rear support (don't plan to either)
"Manage attachments" gives me a blank page, so here is an image link
https://i.imgur.com/rvHmev4.jpg
As you can see the usb-c port is blocked, the ipad is pushed down as far as possible. If the new adapter was recessed just a little bit lower, it would work... Also would be good to update the cradle's shape for a snug fit
thanks
  #27
Old 04-22-2019, 07:44 AM
Eddie, I'd like to return the dock adapter this week for refund and also get a return shipping label for it due to incompatibility. I don't want to use an ASC for this and am not familiar with Avid support, how would you suggest that I proceed?
  #28
Old 04-22-2019, 08:51 AM
EddieJones's Avatar
Please check out this link https://shop.avid.com/ccrz__CCPage?p...calReturnsForm
  #29
Old 04-22-2019, 09:36 AM
"unopened and unused" - hope that won't be a problem
  #30
Old 06-12-2019, 10:45 AM
Hi - I returned my dock adapter. I am wondering if there are any plans to manufacture a new version of this that fits the latest model of ipad?
Again the biggest problem is that the usb-c charging port is blocked.
thanks
Support iPad Pro 12.9? Ray Sean Pro Tools | Dock 3 09-20-2016 12:57 PM
iPad Pro 9.7" VS. iPad Air 2 ? reichman Pro Tools | Control 1 08-07-2016 10:46 PM
Anyone have pics of iPad mini and iPad Air side by side! Brandonx1 Pro Tools | Dock 4 06-07-2016 07:03 AM
Does PT First support Avid Control iPad app? atkeyboards Pro Tools | First Discussion 2 03-06-2016 03:41 PM
Ipad 2 is here! nst7 Pro Tools 9 17 03-03-2011 02:40 PM
