Automation knobs
So, just got my Dock delivered..
After D-Control and D-Command mixing Eucon is a step back.. Customizable... Just make a controller that's versatile, dedicated and reliable! Anyway, back to the present time: The automation mode buttons on the left; why do they only work if I have to press "alt" at the keyboard the same time?? It's really annoying. And having the preview modes layered under the automation buttons is a very weird brainwave.. Oh, and give us linear potentiometer movement back! Thank you |
Re: Automation knobs
With Alt off you press and hold the automation function you want and then select on the tracks or mixer view the tracks you want to apply that too.
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
NO, on the S6 I use the "F" button per channel to get into the automation mode I want (because the S6 Euphonix designers forgot to implement an automation button..)
So I guess the same guys worked on the Dock, because nothing is straightforward. No again, I can't press and hold "write" and then select a channel to apply to. Here the automation buttons only work when pressing "alt" at the same time. BTW: the "alt" key on the keyboard I mean, not the "ALT" key on the Dock |
You can also enable the preference in EuControl Settings>General for "Rec/Auto switch press changes automation modes..." so that you can simply press the Rec/Auto button to toggle automation modes without holding SHIFT button.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Ok, cool. You can also hold the desired auto button and tap a track tile/strip in Pro Tools | Control to change auto modes.
Will I be able to assign control knobs on a midi keyboard to automation ? | John H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-17-2010 01:57 AM |
PC main unit w/ clicky knobs want smooth knobs | Brandonx1 | ProControl, Control|24, Command|8 | 6 | 10-20-2008 11:34 AM |
Where Can I Get Knobs to Replace Missing Knobs on 002R? | akakpaws | General Discussion | 4 | 06-05-2007 08:47 PM |
Digi 003 replacement knobs (003 knobs suck) | volta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-27-2007 02:25 PM |
Do the Knobs Come Off? | bloodspoint | ProControl, Control|24, Command|8 | 3 | 09-16-2004 07:19 AM |
