Old 06-10-2007, 12:15 AM
K2warcrew K2warcrew is offline
Default compatible interfaces?
Im using mbox 2 mini which uses pro tools le. My question is, im i able to use any type of interface with the le software. I was thinking of upgrading.
Old 06-10-2007, 01:34 AM
Stiff Stiff is offline
Default Re: compatible interfaces?
Any type of interface? No my man, you'll have to use either one of the Mboxes or the 002/003. You could use other things as front-ends though...
Daily news & reviews
www.ProToolerBlog.com
Old 06-10-2007, 10:53 PM
Celestial Celestial is offline
When upgrading, it is always good to keep in mind your purpose. What are you going to need? LE is compatible with M-box 1 and 2 and Digi board 002 and 003. If you want to be very portable, inexpensive, and don't record more than two tracks at once, than an M-box 2 should do the trick. If you want to set up a small home studio, and record up to four tracks at once, then I recommend the 002 board.
As far as upgrading to any other hardware, no matter what PT version you have, the hardware has to be Digi powered to be compatible.
Which M-Audio Interfaces are compatible? bilco Pro Tools SE and Essential (Mac) 7 09-23-2014 03:11 PM
Interfaces compatible with PT 10 / 11 TruestPain FireWire and USB Audio Interfaces (Mac) 3 04-28-2013 03:10 PM
Is PT9 compatible with M-Powered interfaces? Hercules Pro Tools 9 1 11-04-2010 06:24 PM
Compatible Interfaces for LE?? tom1325 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-06-2009 03:33 PM
Compatible Interfaces JRainone ICON & C|24 0 05-31-2003 03:42 PM
