  #61
Old 02-17-2012, 09:30 PM
bigredsound1 bigredsound1 is offline
Default Re: Manual Delay Comp Problem
Digi support Tech,
I enjoy recording to tape and porting that directly off the repro head into my Daw. Not a problem when recording the main tracks, but overdubs require a record offset to timestamp the audio and have it slip back in time. My current daw allows me to offset the record timestamp by up to 64000 samples. What is the max number of samples -> converted into milliseconds that can be used for the H/W Insert Delay? My typical sample delays at 88.2k are 7772 at 30 ips and approximately 15,000 at 15 ips. So can this amount of delay be corrected for using the H/W Insert delay?
Originally Posted by DigiTechSupt View Post
I should have been more explicit and I also referenced the wrong person.
You don't have to say anything more than once - I get it. Sometimes, though, given the hundreds of DUC posts I'm not able to give every one of them the amount of attention it needs. The comments about someone being surprised that no one from Avid has chimed in is one of the reasons I wanted to at least put something in this thread, though I think, in hindsight, that it was premature.
SteveBoker had it right regarding the H/W Insert Delay in this post:
http://duc.avid.com/showpost.php?p=1711016&postcount=30
Now, unless I'm mistaken, that should work for you. Yes, I know you're NOT using inserts, but we're just doing this as a workaround. I should have been more clear on that.
And, yes, the ability to manually compensate for delays has not been fully implemented yet, for various reasons.
One thing I wanted to point out is that delays in interfaces should automatically be compensated for via the ASIO or Core Audio polling that occurs at driver level and the only manual compensation that should be needed is when you have an external device in your recording chain that's inducing additional delays.
I did want to point something out, though - you say:
The RME is your interface you're using for Pro Tools, correct? If so, it should automatically be compensated for as long as it's reporting it's correct delays via the ASIO or Core Audio driver. The only delay you should have to compensate for is for the device(s) between the microphone and the RME. Is that what you're doing? The buffer in the RME, if it's the primary Pro Tools interface, is automatically compensated for.
  #62
Old 05-06-2015, 01:18 PM
escobardaniel's Avatar
escobardaniel escobardaniel is offline
have you solved your issue?
I have a similar.
I'm using the non-HD version, 10.3.10, I've sold my crap 003, and bought the pro40 focusrite, that's sounds greater, but, I cannot use my outboard gear to mix phase issues (I cannot adjust parallel compression hearing the inbox signal beside the outbox signal)
  #63
Old 03-17-2019, 04:32 AM
LSD-Studio LSD-Studio is offline
We are aware of the usability problem that is caused by not having user-definable record delay compensation and will look at ways to possibly improve this in the future.
c.
so...8+ years later, is there any way to manually set an offset for Apogee, Lynx etc interfaces?!
I'm combining Avid HD with an Apogee converter and the input delay comp doesn't work properly, so there's an offset between the Apogee and the Avid converter when using both converters on the same source (drums for example).
it would be so simple to just manually set an offset for recording delay comp for the Apogee, much like it's possible with HW inserts...why has that still not been implemented yet?
[IMG] code is Off
HELP!! Bouncing-in-place by recording to new audio tracks - delay comp problem johnnybigmoose Pro Tools 9 9 12-31-2012 01:36 AM
PT 10.0.0 HD Native Automation Problem with Delay Comp Chris Trent macOS 5 01-07-2012 03:04 AM
Delay Comp problems again, Delay comp is RED but way below limits. soundeq Pro Tools TDM Systems (Mac) 13 11-29-2011 12:01 PM
since cs3 intermittent UAD/Wrapped plugs delay comp problem crizdee Pro Tools TDM Systems (Mac) 9 06-16-2009 09:12 AM
Problem with Delay Comp. and not enough DSP/Time slots... storm-01 Pro Tools TDM Systems (Mac) 0 08-16-2007 01:54 PM
