Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 03-25-2019, 07:01 PM
DrJasonK DrJasonK is offline
Default Cleaning up an iPhone recording
I am a hobby musician, singer-songwriter who records in my basement studio on ProTools 12 on a Mac Mini through a Safire interface. I was given some audio of a family holiday event recorded on an iPhone and asked if I could clean it up. The quality is not bad, it basically needs the voice brought out more. It is a singer, guitar and cajon percussion. The cajon is the problem, it is overpowering, too loud. It seems to cross about every frequency I could try to EQ out. I tried to put some kind of gate on it, but it cut out the voice and guitar. I know there are limits to what I can do with this audio source, but wondered if someone out there had some tricks that might help me improve what I have?
Old 03-30-2019, 11:31 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Cleaning up an iPhone recording
Hard to say for sure without hearing the recording. EQ would be one possibility to try to diminish unwanted noise - possibly a high-pass filter to remove lower frequencies and then narrower bands to remove noise at certain frequencies. You might also experiment with noise reduction plugin processing such as iZotope.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 03-30-2019, 04:05 PM
Sardi Sardi is offline
I do audio repair/enhancement stuff everyday. There are limits to what can be done, but with the right tools and know how, it’s quite mind blowing what can be achieved these days. Without hearing the audio, it’s hard to comment.
Have you thought about just hiring someone to do the work for you? I know everyone wants to do everything themselves these days, but sometimes it’s best to just farm out the work to someone that specialises in this type of work. It’s probably a lot cheaper than buying a bunch of plugins or wasting time that could be better spent doing something else.
Old 03-31-2019, 07:46 AM
Thanks for the suggestions! I am generally a DIY type and sometimes the process of trying to do stuff is as important to me as the end result. That said, the recording came from a family event. It would be nice to get it done properly, but I wouldn’t spend a lot of money to do it. I could spend a little on a Plug-in, if I might use it on other projects, although for my own projects, the stock plug ins, usually work fine. What would I expect to pay and where do I look for someone to work on it, if I did hire it out? Is there a specific iZotope plug in I should look at if I went that route? Thanks!
Old 03-31-2019, 10:25 AM
The Weed's Avatar
The Weed The Weed is offline
As a start, either iZotope's RX Elements or Elements Suite. Check on line, some stores like B&H have a sale on.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Issues with iPhone Tapatalk iPhone client stevedemena General Discussion 0 06-21-2012 02:54 AM
Best way to start stop recording in PT via iPAD/iPhone NJ Soul Virtual Instruments 4 10-26-2010 01:25 PM
Best way to remote trigger recording in PT via iPAD/iPhone NJ Soul Pro Tools M-Powered (Win) 1 10-26-2010 10:23 AM
Cleaning up old live recording Diesel10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2003 09:30 AM
Cleaning up old recording Tito Ricci Arballo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-12-2003 01:02 PM
