Old 04-01-2004, 09:25 AM
hobo123455 hobo123455 is offline
Default system bar in sys usage window
Mine goes across about 75% in some sessions but the cpu bar is only about 30%. What does that mean?
Thanks
Old 04-01-2004, 09:58 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: system bar in sys usage window
lower your buffer to 256 and the system meter should hardly move, but CPU will go up. System meter moving is not bad unless you are already at low buffer.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 04-01-2004, 11:25 AM
I'm at 1024 buffer.
Old 04-01-2004, 01:24 PM
Cliffy_Boy's Avatar
Thats why. It just means that the system is working. Less strain on CPU. If you lower the buffer, the system meter will reduce activity.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 04-01-2004, 02:21 PM
Thank you!
System Usage Window not as described dts350z Pro Tools 10 1 11-09-2011 05:07 PM
Help with System Usage Window!! Drummersound Pro Tools TDM Systems (Mac) 4 09-12-2011 08:48 AM
System Usage Window zlr77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-09-2011 09:54 AM
System Usage window. maccool Tips & Tricks 2 04-16-2005 01:37 PM
system usage window?? carbomb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-03-2002 07:54 AM
