Old 02-11-2001, 03:03 PM
CCash CCash is offline
Default Plug-in \"snapshot\" recall automation?
Ex: you're using an EQ plug-in on a track. You find two very different EQ setups for various sections of the track.
You save the 2 plug-in settings, and now you want to recall them as needed throughout the track.
I've found that with Write automation enabled, I can manually recall the other saved setting "on the fly", but it's imprecise and there's probably a more elegant way to do it.
I know I could have the same plug-in on two inserts with the different settings and bypass them as needed, but that's not what I'm after. Is there a simple way to automate recall of saved "snapshots" of plug-in settings? Did rtfm.
Old 02-11-2001, 03:45 PM
Kenny Gioia Kenny Gioia is offline
Default Re: Plug-in \"snapshot\" recall automation?
I've never tried this but it should work.
Set up your first setting and write all the settings at the beginning of the song.
Then go to the second section, put automation into auto off. Then change your settings to settings 2 and then go into write mode. Then hit play for that section. Hope that helps
Old 02-12-2001, 04:33 AM
Zeus Zeus is offline
There is a keyboard shortcut called "write automation" (TDM-systems only): apple + / for the currently active parameter (the one visible on the track's data view) and apple + option + / for all automation enabled parameters. I have sometimes used it to automate faders, pans, send levels and eq's. However, yesterday I wanted to use this with Autotune's "keyboard" parameter, but it did not work out... Neither did recording automation in "write mode"...
Old 02-12-2001, 09:52 PM
Thanks both of you for your time. Produceher, that works just fine. Thanks.
Curt
Snapshot/plugin recall issue Realdon VENUE Live Sound Systems 5 05-01-2012 02:27 PM
No gate on / off recall on snapshot?? Audioartist VENUE Live Sound Systems 0 05-18-2010 03:49 PM
Snapshot recall of the patchbay BHSoundman VENUE Live Sound Systems 4 08-06-2006 07:36 PM
Snapshot Plug in Automation from HD to LE Mubeau Post - Surround - Video 1 07-05-2005 06:39 PM
Plug-in Snapshot Automation? José Luis Díaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-27-2004 03:41 PM
