Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-16-2021, 01:17 AM
Firechild Firechild is offline
Default Audio clip Waveform height to show 0dBFS correctly?
I can´t zoom/change waveform height to correctly reach top or bottom when audio is 0dBFS.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 01-16-2021, 02:06 AM
JCBigler's Avatar
JCBigler JCBigler is offline
Default Re: Audio clip Waveform height to show 0dBFS correctly?
Why are you recording at 0dBFS? That's way to hot. And you're going to get digital distortion at that level anyway.
My levels are usually down around -20dBFS, or lower sometimes.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 01-16-2021, 05:16 AM
midnightrambler midnightrambler is offline
option-cmd-[
Old 01-16-2021, 12:15 PM
The Weed's Avatar
The Weed The Weed is offline
Tangentially, waveform height is no indication of signal strength.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-16-2021, 01:24 PM
Top Jimmy's Avatar
The standard waveform view at default is -0 at top or bottom edge, -6 halfway from center to edge, -12 one quarter from center to edge. Simply viewing the waveform gives a real good indication what your average and peak levels are. Older versions of PT showed this clearly and concisely, but at some point (maybe when floating point files became supported) they appeared to have fudged in a little more space near the edges. But the default waveform view logarithmic visual relationship is still there.
James Cadwallader
Old 01-16-2021, 01:26 PM
Top Jimmy's Avatar
Probably because while you are at -0, there’s still a little bit of space left before the edge. It’s just a visual thing.
James Cadwallader
Old 01-16-2021, 04:18 PM
The Weed's Avatar
Allow me to rephrase: "Tangentially, waveform height is not always an indication of signal strength unless, if you have changed the waveform height, through the Zoomer Tool or keyboard+mouse shortcut, you reset the audio waveform height to default by Command+Option+Control+[ Mac, Control+Alt+Start+[ Windows.
SonoBus
Old 01-16-2021, 04:42 PM
Top Jimmy's Avatar
Yeah, that’s the ticket!
James Cadwallader
Old 01-16-2021, 05:29 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Why are you recording at -20dBFS, that is way too low
But seriously. You don't have to record "hot" or "low", you have to record "correctly". The main rule is not to clip. While 0dBFS is technically not (yet) clipping (no digital distortion), it all depends on how the meter is calibrated and how many FS-words it counts before showing you the red card (different story for bouncing with 0dBFS). If your peak is at -2dBFS, then chances are you did not clip on the way in.
The only reason to operate in such a low range of -20dBFS is if you want to keep that much headroom for any "uncertainties" of the performer, or you have your analog equipment calibrated to +4dBu = -18dBFS (or for sentimental reasons).
If you record in 16bit and your peaks are at -20dBS (or lower), then you have a 76dB left of headroom to the least significant bit and the nasty Quantization Distortion. This might be ok for a kick drum, but for any acoustic recording, maybe not. Recording a choir in a church with a nice reverb tail, then that end of the reverb might be gobbled up in that Quantization Distortion.
Recording in 24bit, of course, a different story.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Changing Waveform Height fastdog Windows 2 01-13-2016 05:36 AM
Waveform height bug? DJ Hellfire Pro Tools 12 6 10-12-2015 10:10 PM
clip waveform doesn't match audio phillyt2k Pro Tools 10 2 04-19-2014 04:36 AM
Waveform height Stig Eliassen ICON & C|24 14 10-30-2011 02:25 PM
Vertical zoom to show default waveform height (Audio) with D-Command ? Hanswurstlsepp ICON & C|24 0 06-30-2011 03:55 AM
