Re: Digi 002r clarification needed on digital I/O (S/PDIF) standards
While it may work, using a cable to shoehorn an AES signal into an SPDIF input has the potential to either not work at all, or even worse to work, but unreliably. In my opinion A digital signal that is less than 100% accurate is much worse than a digital signal that doesn't work at all. The reason is that anything you record with a jittery digital signal is garbage, and you may not notice the glitches until after the recording, when it's too late. A completely non-working digital connection however, will stop you from making a recording entirely, so you don't waste the time and energy of making a recording only to find out that it's full of digital artifacts when you go to mix it down. I have been using my ODL-312 since 2006, it's never failed me, always worked perfectly and never needed any kind of troubleshooting. These little boxes also seem to hold their value very well( I think it was $90 new, I've seen used ones go for $75), so if you ever end up not needing it, there's always ebay.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Just and FYI, it looks like the box you need is the HOSA CDL-313 (AES to Coaxial SPDIF).
The clock would be syncing over light pipe as well - still shouldn't be a problem with your proposed setup, right? |
Does Digi 002 accept optical SPDIF? I didn't think it did, but if it does, then yes the ODL-312 will work fine. You do not need any external word clock cabling, but you will need to set your 4-710d to be the master clock, and set your digi 002 to external clocking.
UPDATE: Yes it does support optical SPDIF.
#16
Buttdialed by me & Tapatalk
#17
Of course, I'll inevitably upgrade to a newer (better) interface eventually, but as it stands I still prefer working with my 002 over this RME Fireface 800 I've got on loan (gasp)! Focusrite has a new rackmount that looks rather good... |
#18
There are a few odl-312s on ebay right now for $45. Pretty much a no brainer at that price.
#19
After you've had to switch the optical cable a few times, you'll wish you had the AES to coax S/PDIF converter instead.
#20
Why would I need to switch the optical cable?
How do I connect external effects to a Digi-002R via S/PDIF? | AntManBee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-12-2013 04:20 PM |
DIGI-002R S/PDIF not working | socko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 12-05-2010 09:44 PM |
Layback standards digital files for TV, help! | hitp | Post - Surround - Video | 6 | 07-26-2010 07:33 PM |
Digi 002 s/pdif to recognize input from digital MPA | toddbux | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-07-2008 11:52 PM |
Using digital montiors (S/PDIF) on Digi 002R? | MartinSz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-28-2006 05:53 AM |
