Old 11-29-2019, 12:09 PM
rtd3audio rtd3audio is offline
Default Rolling-back Pro Tools 10.3.9 Factory Plugins
Hey there,
So I recently updated from Pro Tools 10.3.9 to 10.3.10 in the hopes of solving another issue. The new problem that I have now is that updating to 10.3.10 updated all of the factory plugins bundled with Pro Tools such as signal generator, AIR Plugins, etc.
At first, this doesn't sound like much of a problem; except that I was using the older version of the signal generator to produce some really cool/unique sounds for a client of mine. The new version of the signal generator must have a different algorithm for producing saw waves and other things, so the sounds that I had built for this client are now broken and/or not sounding as intended. On the last call I had with that client, he said that was his favorite sound, and he wanted to explore more uses of it. So I am desperately trying to get it back.
I have since tried deleting preferences and plugins folders, uninstalling 10.3.10 and reinstalling 10.3.9, even system restore. But the signal generator, AIR Plugins, etc. remain updated no matter what I do.
I'm wondering if anyone can point me in the right direction of rolling-back this update to the factory plugins so I can get the older version of the signal generator back. Or perhaps there's a legacy download somewhere out there that has what I'm looking for. I actually don't mind the rest of the updated plugins, it's really just the signal generator that I need the older version of.
Thanks for all the help,
Robbie
Old 11-29-2019, 12:24 PM
Default Re: Rolling-back Pro Tools 10.3.9 Factory Plugins
Windows can get weird, to say the least, in uninstalling programs. There's all sorts of crud that gets left in the registry. I'd suggest after uninstalling everything PT related you can find through the 'normal' Windows uninstall routines to take a trip through the registry with CCleaner and clean out the registry. As always make a copy of your registry before mucking about in there.
Yeah - I know - I'm on a Mac now but I used to be hard-core Windows. Still keep an old Winbox around whose sole purpose is Sony CD Architect 5.2. Actually one more purpose - some decent flight sims
Jack
QAPLA!
Old 11-29-2019, 12:39 PM
Well, I'd like to avoid longshot fumbling around in the registry. Are there any legacy downloads or more assured ways to get the older version of the signal generator?
Old 11-29-2019, 02:09 PM
Getting the download isn't really the problem. Sorry but you're going to have to go through the registry. Just make sure you have a copy of your working system and registry before you go in there. You do make regular backups of your system right?
Jack
QAPLA!
Old 11-29-2019, 05:29 PM
Ben Jenssen's Avatar
...aah, microsft flightsimulator...mmm.
Sorry. Carry on.
Seriously, though; are you (rtd3audio) quite certain that signal generator did change? I can't see why it would have.
Old 12-01-2019, 10:33 PM
So after literally backing up my entire 900GB+ drive, formatting, and updating to Windows 10, I can confirm upon fresh install of Pro Tools 10.3.9 and even 10.3.8 that the updated plugins are included in the install package from this link: http://secure.digidesign.com/service...rticleId=43412.
Yes, the signal generator (and all other factory plugins) changed.
Old one looks something like this: https://tinyurl.com/vnjvydw
New one looks something like this: https://tinyurl.com/ueu4qjr
But looks are not the only thing that changed between versions. The old one sounds more granular, while the new one sounds more smooth. This is only problematic for my specific use case, I know. But I would love to not have to tell my client that I lost his favorite sound generator while troubleshooting for another problem (that has since been solved by updating to Windows 10 by the way).
So... anyone have access to a legacy download that will have the legitimate factory plugins from the 10.3.9 version?
Old 12-02-2019, 01:59 AM
unkJE's Avatar
unkJE unkJE is offline
Looks like you’re after the 32-bit RTAS version of SIGNAL GENERATOR – and thus, a co-install of Pro Tools, which requires the lower-number version of Pro Tools to be installed first.
Pro Tools 10.3.6 (or higher) can be installed simultaneously under Windows 7 SP1.
This Compatibility Chart says Pro Tools 10 needs Windows 7 SP1:
http://avid.force.com/pkb/articles/e...tibility-Chart
Although not supported, some claim to have Pro Tools 10 working on Windows 10 – although Windows 10 is not supported for co-install:
http://avid.force.com/pkb/articles/e...ll-Information
If you want to try your luck anyway, you could download the Pro Tools 10.3.7 Win Installer from the bottom of this page:
http://avid.force.com/pkb/articles/e...ads&popup=true
If that doesn’t work – try Pro Tools 10.3.6 or Pro Tools 10.3.8 from The Download Center – a repository of legacy and current versions of Avid Software:
http://avid.force.com/pkb/articles/e...ownload-Center
CCleaner Free is easy to use – and should be used when updating, to clear out the “old stuff”.
https://www.ccleaner.com/
https://support.piriform.com/hc/en-u...load-CCleaner-
Run CCleaner then run CCleaner Registry (from the left-hand column) then restart computer
When using CCleaner Registry, after "Scan for issues" and "Fix selected issues", select "Yes" to "back up the registry before making changes" in My Documents>CCleaner>Registration Entries
Hope this helps!
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 12-02-2019, 09:56 AM
The Weed's Avatar
The Weed The Weed is offline
And sometimes you have to run CCleaner's Registry Cleaner more than once after it finds issues as it may take two or more "sweeps" to find all the Registry issues. And yes, save a copy of the Registry to a folder each time it asks, it's easy to import a Registry backup.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-02-2019, 04:16 PM
Hope this helps!
I realize now that the picture I included as an example of what the old version of the plugin looked something like is the 32-bit RTAS version as denoted by the RTAS in the top right of the picture. The version I was using, however, did NOT have that. Sorry, I should have been more clear. I was just quickly grabbing a google image search of the old version's GUI style.
Here is a more accurate picture of the old version of the signal generator plugin: https://www.protoolsisawesome.com/wp...lGenerator.png
I have been testing various installs of Pro Tools 10 versions on my now Windows 10 OS and can confirm/use Pro Tools 10.3.8-10 easily from that link I provided earlier. I use a clean system restore point that I created myself in order to revert the Pro Tools installs. This helps me avoid registry fumbling. I can confirm that 10.3.7 does not work out of the box on Windows 10 and would require a great deal of adjustments just to be able to open it.
All of this being the case, I'm not so sure that co-installation is the answer I'm looking for, nor the 32-bit RTAS version of signal generator for that matter.
Straight from my old, Windows 7, backed-up Local Drive, the new version of the multi-mono signal generator is an AAX plugin found at \Local Disk\Program Files (x86)\Common Files\Avid\Audio\Plug-Ins\SignalGenerator.aaxplugin. I would assume that the older version of this plugin would also be an AAX plugin. Would anyone happen to have a copy of this plugin that looks like the picture? That would be the most ideal, I think.
Old 12-02-2019, 04:26 PM
Southsidemusic's Avatar
Are you looking in the audio suite dropdown as that last picture is a audiosuite version.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Rolling back Mitch Griffin Pro Tools 12 7 10-07-2016 01:36 PM
Rolling back jeff5x0 Windows 4 05-01-2012 06:39 PM
Rolling back firmware on SYNC HD nasher99 Pro Tools TDM Systems (Mac) 1 12-02-2010 09:41 AM
>> Rolling back and forth between PT 7.3.1 and 7.4 Howardk Pro Tools TDM Systems (Mac) 3 11-23-2007 10:40 PM
Error after rolling back to 12.5 Pro Tools 12 0 12-31-1969 04:00 PM
