Old 11-09-2001, 10:15 AM
cebolao cebolao is offline
Default can\'t record with command-space
...because i installed system 9.1. it "catches" the command-space shortcut and uses it for switching between keyboard layouts. i tried to turn this off in control panels, but couldn't do it. anyone can help me?
i know i can record with f12 button, or with my control24, but i really love the command-space shorcut, especially when recording many takes and command-dot (erasing current take) is much in use.
thanx
cebolao
Old 11-09-2001, 11:21 AM
Mt.Everest Mt.Everest is offline
Default Re: can\'t record with command-space
Im not sure if you tried this but under the little flag in the top right corner of the mac file menu you can change your keyboard options.. There you can disable hot keys to switch layouts...
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 11-12-2001, 05:45 AM
mh mh is offline
Hello,
I had the same problem. I tried to trash all keyboard prefs etc. No help. Only solution I found was clean install of OS.
Matti
Old 11-13-2001, 02:33 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by mh:
Hello,
Matti
<HR></BLOCKQUOTE>
hello, mh. which os version did you install? can you turn this feature on/off during installation? my problem began when i installed mac os 9.1.
cebolao
Old 11-14-2001, 01:23 AM
mh mh is offline
I have OS 8.6.
I think it was language option for keyboard. Can't remember surely, sorry. But I had the flag menu (upper right corner of the finder) full of Japanese and Korean etc. options that I could not turn off (from anywhere).
It might be that just the clean install will do it. Check if there is any options for languages when starting clean install.
Hope this helps,
Matti
Command-space bar not working zoff Pro Tools M-Powered (Mac) 19 09-05-2020 07:43 AM
f12 words, but command space doesn't? hornedrum macOS 7 01-11-2015 09:28 PM
where is the command+space gone ? groovebrother Pro Tools TDM Systems (Mac) 14 11-27-2012 02:16 PM
Command + Space shortcut in Snow Leopard oha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2009 08:49 AM
TL Space TDM Plugin causes Command 8 to lose communication jacobfarron ProControl, Control|24, Command|8 3 06-20-2008 09:54 AM
