Old 01-16-2006, 08:28 PM
abbyin3d abbyin3d is offline
Default What does the \"Auto Join\" tab do?
I noticed in PT 7 there is a tab at the bottom of the Automation Enable window called "Auto Join." I can't find it in the manual. What does this do?
Abby North
Synchronized Soundworks Production Music Catalog
www.sspmc.tv
310.459.4707
Old 01-16-2006, 08:53 PM
Default Re: What does the \"Auto Join\" tab do?
The same as JOIN MIX on an SSL. If you don't have a control surface.. don't worry about it.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-17-2006, 09:44 PM
So what does it do on an SSL?
Abby North
www.sspmc.tv
310.459.4707
Old 01-18-2006, 01:55 AM
Pete Gates Pete Gates is offline
Unfortunately Auto Join on Protools is nowhere near as good as Join Mix on an SSL. What they've implemented is useful but not anywhere near as useful as it could be.
On the SSL (and Harrisons and DFC) you can rehearse/tune a 'scene' then punch in those final control settings. Controls you haven't touched remain as they were. It's fantastic for post work (my area) though I could imagine it'd be pretty cool for music too. On Protools it just punches in the controls that were put into write (good) but NOT with the last setting you've arrived at (bad), just with the setting at that point in the automation. Kinda hard (for me!) to explain, easier to demonstrate.
I'm hoping that Digi will soon introduce new automation features that will improve this.
Pete
Old 01-18-2006, 07:39 AM
Drew Mazurek's Avatar
yea, in PT you're better off using Write/Trim to selected parameters.
www.drewmazurek.com
glitch with auto join in PT 10 mixify Pro Tools 10 3 06-25-2013 02:18 PM
Auto Join Inconsistency midnightsun ICON & C|24 4 01-25-2009 01:32 PM
Auto Join and Trim mode thermisonic Post - Surround - Video 2 01-15-2009 08:36 AM
6.9 and "Auto Join" grayed out? InjuredEar ProControl, Control|24, Command|8 6 06-07-2005 12:57 AM
