Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 01-24-2017, 05:43 AM
Julfr Julfr is offline
Default Need help : fast track m audio + mac os 10.9.5 + PT issue
Hello,
I have some issues with Pro Tools.
I want to rec a voice over with my Mac OS 10.9.5
5 years ago, I bought a fast track m audio (with pro tools M-Powered Essential 8.0.3). I tried to install PT 8.0.3, but the software is not able to complete the process : the application isn't correctly installed.
So, I thought it was a compatibilty issue : I decided to download a newer version, Pro tools First.
And finally, PT doesn't work at all : when fast track audio is plugged, PT doesn't work. I receive some alerts like "the program doesn't support other frequency (48kHz is my choice, but the software only purposes me 44,1kHz)
Someone can help me please ...? Should I download another update of pro tools ? Or just sell my Mac
Thank you
Old 01-24-2017, 06:10 AM
Default Re: Need help : fast track m audio + mac os 10.9.5 + PT issue
I decided to uninstall PT first. Then I tried to install PT 8.0.3 one more time. Same problem at the end of the process : after 15 minutes I decided to stop the program... I reboot my mac and Pro tools application seems to work ... But doesn't recognized fast track :-/
Old 01-24-2017, 06:46 AM
I found the solution in another forum : http://community.avid.com/forums/t/124237.aspx
If you have the same problem, read above :
"Hi
I have actually solved the Fast Track USB problem and it now works with Mavericks!
I downoaded this file> http://akmedia.digidesign.com/suppor...80533.dmg?ns=1
you can find the file here 1.9.5. http://avid.force.com/pkb/articles/e...rue&popup=true
The computer restarted
Then I uninstalled the drivers through the same file.
I also deleted the folder Avid here.. /Library/application support/Avid
Now my M-Audio Fast Track USB works!
Hope this also help you.
//// This took me 4 weeks to solve... To Avid. I am Not Impressed by you guys! Regards Sweden"
Bye
Fast Track USB II (ml03-00454) audio interface (Code 10 issue in device manager) AudioRaOp FireWire & USB Audio Interfaces (Win) 0 10-07-2016 12:42 PM
M-Audio Fast Track Pro Audio Output issue in Win7 tamal_g Windows 3 04-04-2016 07:08 AM
Sound is playing too fast with M-Audio Fast Track Pro wodkin FireWire & USB Audio Interfaces (Win) 0 02-06-2015 09:42 AM
MIDI Issue With M-Audio Fast Track Pro & Command|8 kavieix Pro Tools M-Powered (Win) 0 03-28-2008 07:53 PM
M-Powered issue with M-Audio Fast Track USB Jesse1 Pro Tools M-Powered (Win) 8 11-27-2006 12:54 AM
