Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-31-2020, 10:02 AM
DonnieJ's Avatar
DonnieJ DonnieJ is offline
Default Re: 2020.3 is out
Downloading now!
Old 03-31-2020, 10:40 AM
Southsidemusic's Avatar
Originally Posted by K.I. View Post
Hi.
Crash when saving session and clicking to launch. why?
Crash after boot even in 1ch empty session!
The same is true if you delete the default settings
I use Mojave.
PTU 2020.3 runs great so far on HS/Mojave and tried a quickie on Catalina and seem to be smooth and faster.
Will dig into the track folder option now!
In Live10Suite we need to tell Live to make the outputs setup automatically when adding new tracks so maybe the same for PT. It does need to be added manually it seems when you add new tracks to a folder. Anyone else seeing this?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-31-2020, 10:55 AM
Downloaded the 2020.3 update - there's something to be aware of. Thankfully the installer warns us that the update makes changes to the workspace file and that those changes make it so it won't work with earlier versions of PT. At least in the Mac version we're also given the path to that file so we can make a backup of it before installing. This means no having multiple versions of PT on the same machine's boot volume if you have OT 2020.3 and follow-ons.
Disappointed Avid hasn't fixed the issue I raised about deleting events in the MIDI event list. I've been in touch with tech support at Avid and they can repro it. They gave no ETA on a fix though. Disappointed it's not been fixed here. So I'm back to PT 2019.6. I know that's SO last decade but it's what I need to use because of my using a LOT of MIDI.
Jack
QAPLA!
Old 03-31-2020, 10:59 AM
audiobob's Avatar
audiobob audiobob is offline
This will be the first version where I feel comfortable upgrading to Catalina. There is finally video import and audio from video import via 3rd party apps. I can work with that.
How are you all upgrading to Catalina? Back up and install over Mojave or start from scratch? I use to start from scratch every time but man that takes a while.
Old 03-31-2020, 11:05 AM
TrentWilliams TrentWilliams is offline
Wow.
Folder tracks are BOSS!
Updating all my templates.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
  #16
Old 03-31-2020, 11:08 AM
And you guys thought we wouldn’t get a March update
Good times again (for most)
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #17
Old 03-31-2020, 11:22 AM
grayter1 grayter1 is offline
Running great here on my Windows box.
Omnisphere still hits the CPU harder than it does in other DAW's at 64 Samples, but it is what it is. Heavy instrument plugins continue to stack up on one CPU lane/core and aren't as evenly distributed as others.
However, I've moved to a freeze/commit workflow with VI's in PT, so it's all good, and overall things feel a bit snappier.
YMMV...
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
  #18
Old 03-31-2020, 11:30 AM
K.I. K.I. is offline
Hi.
test!
1. Create a new session
2.1tr only
3. Save.
4.pt closed
5. Click on the saved session! !
6.pt2020 crash
  #19
Old 03-31-2020, 11:34 AM
test!
2.1tr only
3. Save.
4.pt closed
6.pt2020 crash
Just tried it here and it's fine. No crash. I'm on a PC though.
tg
  #20
Old 03-31-2020, 11:36 AM
HotelRadio HotelRadio is offline
Haven't had any issues (so far) running it on macOS Sierra 10.12.6.
Pro Tools 2020.1 off the wall Pro Tools 2019 141 11-28-2022 01:59 PM
2020 PT-Release belasoul Post - Surround - Video 6 03-10-2020 03:17 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Does anyone use XV-5080 or XV-2020? Atana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-24-2002 10:52 PM
