How to make ASIO default for Audio Playback
Hey all,
Putting my new computer together. Got past the Blue Screen of Death (thank you DEP fix advisers!) Things are looking good now, except: I'm trying to make my computer use the Digi001 box and the ASIO driver for all the audio playback. Right now it's defaulting to the SoundMAX digital audio card that came with my computer. When I go to the Control Panel - Sound area, I don't see an option to default to ASIO. Now...Fruityloops (brilliant program that it is) seems to automatically find the Digi001 box and allow me to send everything through it. But...I am not having the same luck with Winamp and more importantly...my stand alone T-RackS. I tried the Rail Jon's MME helper and added both programs, but still...no dice. Now that I'm thinking this through...should I be installing WaveDriver and not think about ASIO for T-RackS? Does WaveDriver come with the 6.4 install or is it a seperate install? Please help! Thanks! -todd http://bartlebymusic.com
https://soundcloud.com/user-496684376 |
Re: How to make ASIO default for Audio Playback
You need to install the wavedriver. Here's a link to the page Wavedriver . Add t-racks and other things that don't have a setting for using wavedriver for playback with Rail's MMEHelper
https://www.thirdeyerecording.com/ |
Thanks for the tip!
I'm downloading it now, but I just realized that my 6.4 installation automatically installed WaveDriver. It says so also on the WaveDriver download page. So I guess I do have it and I have done the MME helper. Back to square one... I'll try re-installing it with the version from the WaveDriver page. Then I'll uninstall T-RackS and Winamp and reinstall them. Hopefully that'll work. Thanks, -todd
Try Control panel>>Sound>>Audio>>Change Sound Playback to Digi devices on there. That is how I got Winamp to play back properly. You will run into certain apps. that will not use your system pref's though which are a pain, but most everything if you use Winamp, you should be able to play stuff through it and not use other apps besides digi and what not. Goodluck
Verify that it's installed by going to C:\Program Files\Digidesign\Drivers amd you should see MMERefresh. You should also be able to see the 001 in the control panel sounds and audio devices under playback. Make sure it is set there too, like mr. penguin said.
Thanks for all the help!
I did look under control panel/sounds and only saw the SoundMAX card listed. Any idea how to get the Digi box listed there? Thanks, -todd
Just to clarify, when you went to sounds in control panel, did you click on audio, and look at it there under sound playback?
I'm almost 100% positive that's where I looked.
I will check again this evening. Thanks again, -t
HELP!? Make Mbox mini default sound card?! | GrimBandit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-28-2011 01:02 PM |
How to make 44.1 as default ? | Firechild | Pro Tools TDM Systems (Mac) | 3 | 06-04-2011 09:37 AM |
How do you make the mbox2 mini your default windows mic and use it for other apps? | JJBro1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-05-2009 01:11 PM |
I/O setup - make new default? :confused: | RT60 | Pro Tools TDM Systems (Mac) | 4 | 11-01-2005 12:54 PM |
Cannot make default "Open With" setting to PT 6.1 | Stephen Bond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-26-2003 01:17 PM |
