  #111
Old 04-08-2020, 01:48 PM
GoButtonGuy GoButtonGuy is offline
Default Re: 2020.3 is out
Originally Posted by innesireinar View Post
The last thing I want to do is to defend Avid but releasing a version that is still compatible with 4 OS (Sierra, HS, Mojave and Catalina) is not easy. Sierra is 4 years old. I'm on HS and I was crossing my fingers that the 2020.xxx was compatible with it. It is... but I think that the next time HS will be cut and I will have to replace my video card for moving to mojave.
Yeah but it's been that way since the Soundtools/Digi days before Avid swallowed them. In the 90s until today most gigs I'm on are still a few OS and PT versions behind. No matter how many years go by that seems to be the case for many large/mission critical users. We kept an old Tupperware Mac online for several years after it was supported. It's so that many of us have switched tools even though I think Avid is better these days. We use Nuendo to track and mix to picture, PT for some things, and Live for writing, arranging and playback systems. I cut my teeth on 1" 16 track and 2" 24 so I like the music style workflow of PT but these days it's easier to to change the workflow than hassle with the tool. My focus is the art. The tool is only a means to the art.
What happens in Vegas, we make happen...
  #112
Old 04-08-2020, 03:05 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by grayter1 View Post
Running great here on my Windows box.
Omnisphere still hits the CPU harder than it does in other DAW's at 64 Samples, but it is what it is. Heavy instrument plugins continue to stack up on one CPU lane/core and aren't as evenly distributed as others.
However, I've moved to a freeze/commit workflow with VI's in PT, so it's all good, and overall things feel a bit snappier.
YMMV...
tg
VE Pro is a lifesaver. I run the VST version of Omnisphere and other heavy VI's on VEP. That definitely removes a lot of the load off PT, so you can run more tracks and plugins.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #113
Old 04-09-2020, 04:22 AM
+1 for VEPro on even a single machine. There's some stuff in UVI Falcon that bogs down PT and that's where VEPro comes into play. Especially if I'm working on several pieces that use the same instruments. And if you work with it uncoupled that eases things as well.
  #114
Old 04-09-2020, 08:15 AM
innesireinar innesireinar is offline
Yes, Vep is a useful tool that I use everyday. The only issue is that it adds at least 512 samples of latency. When play a VI for programming is very annoying
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #115
Old 04-09-2020, 08:55 AM
I don't use VEPro when actually playing in music and capturing the MIDI. That vi runs in PT and when done with that it goes into VEPro.
Pro Tools 2020.1 off the wall Pro Tools 2019 141 11-28-2022 01:59 PM
2020 PT-Release belasoul Post - Surround - Video 6 03-10-2020 03:17 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Does anyone use XV-5080 or XV-2020? Atana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-24-2002 10:52 PM
