Old 06-27-2011, 10:37 AM
Lee Lundgren Lee Lundgren is offline
Default Accessing SC48 Hard Drive
I was planning on cloning the drives on our D-Show and SC48. The drive access on the D-Show is easy, but not so apparent on the SC48. Where exactly is the drive and how do you access it on an SC48?
Thanks!
Old 06-27-2011, 03:25 PM
rivetheadsound rivetheadsound is offline
Default Re: Accessing SC48 Hard Drive
you would have to remove the top control surface to access the CPU inside. its a series of hex screws around the surface. give tech support a call and they can get you diagrams. its fairly easy. i had to do it when i had to replace all my input cards earlier this year.
Brian Lloyd
FOH Engineer - In The Mood LIVE
-Reality.exe corrupt. Reboot?-
Venue SC48
Macbook 13"
HP 2525TX Tablet
Motion Tablet LE1600
Mac Mini 2.6 dual core with 1TB 4gig Ram
Old 06-29-2011, 06:02 AM
Thanks Brian!
Old 06-29-2011, 10:57 AM
contact tech support and get the details about the 2 sizes of hex bits you will need. getting the exact ones will help alot the screws are very easy to strip.
Brian Lloyd
Venue SC48
Macbook 13"
HP 2525TX Tablet
Old 02-02-2012, 11:35 AM
Greg C Greg C is offline
Has anyone tried an SSD in the SC48? Seems like it would be more reliable and really speed up the boot time...
Greg
Cameron Pro Audio
Exclusively at the Miners Foundry
Old 02-02-2012, 01:34 PM
Tim McCullcoh Tim McCullcoh is offline
Greg... I think this has come up on the forum previously, but IIRC the response from AVID was that they don't support SSD drives in the SC48. I believe they do support it in FOH racks, however.
Sheldon?
Old 02-03-2012, 09:40 AM
DigiFieldService DigiFieldService is offline
Lee,
The hard drive is mounted directly above the CD-ROM in the bottom right corner of the desk. Remove the perimeter screws on the gray fader panel and then remove the cover plate in the bottom right corner to access the hard drive.
-Mike
Old 02-03-2012, 10:39 AM
Lee figured it out. The question du jour is if AVID will endorse/support SSD drives in SC48. See this post up thread...
http://duc.avid.com/showthread.php?p...21#post1897121
Old 02-03-2012, 02:50 PM
Mystere1 Mystere1 is offline
Default
Writes kill SSD drives over time Venue does a lot of writes.
Old 02-03-2012, 04:18 PM
ionStorm ionStorm is offline
A 160GB Intel X25-M over-provisioned to 96GB can do about 100TB writes. I doubt you'll hit that ceiling in the console's lifetime. :)
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
sc48 internal hard disk size? jbialek VENUE Live Sound Systems 1 02-16-2010 08:12 AM
Transfer Volume error when accessing external hard drive Noblesse Oblige 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-07-2008 04:05 AM
PT quits when accessing audio drive in workspace. stunari 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-23-2006 07:04 AM
Accessing drive A...Can't find recent files and folders in XP APAULOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-13-2002 01:31 AM
