Old 07-16-2019, 02:16 AM
RedEyeJedi RedEyeJedi is offline
Default Please Help! Avid Artist Mix Mac - No Connection
Hi guys - really struggling (as always) with my avid artist mix
Runnin lattest version of EuControl with ARtist Mix on MacOs Mojave on a new Mac Mini 2018
Artist is pluggd directly into Mac Mini ethernet port
I also tried using a router/hub to no success.
I have tried with WIFI on and Off, no effect
I have trashed all prefs and restarted numerous times, no effect.
I have changed the port order of priority in network settings. nope.
I have read most articles and forums for the last hour.
My artist mix is set to static with following addresses
IP: 010.000.000.020
subnet: 255.255.000.000
My mac has following
ipv4: Manually
IP: 10.0.0.2
Subnet: 255.255.0.0
- No connecttion, EuControl not finding device
Any suggestions??
Old 07-24-2019, 01:13 PM
Crankster Crankster is offline
Default Re: Please Help! Avid Artist Mix Mac - No Connection
Same situation here...
newest eucon
mojave
mac mini 2018
netgear Switch
artist control & transport
...not showing up in the surface list!
Swapping from a fine running...
eucon 3.7
highsierra
2012 mac mini
netgear switch
...setup that looks more attractive at present.
Guess it´s not caused by the switch and artist devives?
Avid help us out please!
Old 07-24-2019, 01:28 PM
Southsidemusic's Avatar
Did you make sure that the Eucon is enabled under peripherals in Pro Tools as that defaults to OFF or box unchecked when updating Eucon sometimes.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-24-2019, 02:00 PM
Hi Christopher,
In my case it´s a clean install and my devices not showing up in eucontrol therefore they´re not visible in my daw either.
Old 07-24-2019, 03:39 PM
Originally Posted by Crankster View Post
Hi Christopher,
It is not visible in your daw, you just need to activate the eucon check box in peripherals. Is that box checked?
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 07-25-2019, 02:28 PM
Hej Christopher,
Giving the best to help us is highly appreciated but I think we´re not talking about the same!?
I´m on Live/Logic but the main issue is to make eucontrol recognise my artist devices in the eucontrol settings under "my surface"... Devices just displaying the avid logo.
Like redeye I´ve tried everything that came to my mind but no fix so far...
Old 07-25-2019, 02:50 PM
Hej Christopher,
Giving your best to help me/us is highly appreciated but I think we´re not talking about the same... I´m on Logic/Live and not on PT but I guess it doesn´t matter what daw cause the main issue is to get the artist devices recognised by eucontrol in the "my surface" settings!
Like redeye I´ve had tried everything that came to my mind or was suggested but no fix...
Does anybody have 100% connection with Artist MIX? robreed2 Artist Series 38 05-06-2019 10:11 AM
Artist Chat window in Avid Artist Community taylor4814 Pro Tools 2018 0 01-25-2017 06:30 AM
2 avid artist mixes and one artist control V2 for sale Brandonx1 Buy & Sell 2 03-21-2016 09:55 PM
Is there anything we can do about Artist losing connection? K_BCN Artist Series 5 03-08-2016 02:30 AM
Help Avid Artist Control losing connection with logic X using usb to ethernet adapter smartinez5878 Artist Series 4 06-23-2014 11:10 PM
