Old 06-18-2019, 05:14 PM
ToneSetter ToneSetter is offline
Default Bounce to disk: Asio4All vs Interface as Playback Engine
A client hit me up and needs a few easy revisions to a radio edit version of his track I did earlier. I'm not at the studio now but do always keep my backup hard drives with me and my laptop with pro tools 12 on it. My question is, after I make the changes, if I bounce to disk with Asio4All V2 selected as the playback engine (because I do not have an interface with me), will the quality be different or the same as if I had my interface selected as the playback engine when bouncing? I guess the simple version of what I'm trying to ask is, does the playback engine selected affect the quality of the bounce to disk? Thanks in advance for all input
Old 06-18-2019, 05:51 PM
Default Re: Bounce to disk: Asio4All vs Interface as Playback Engine
Unless you have some hardware inserts, the interface should have zero effect on the sound of your bounce(because audio doesn't pass thru it in the BTD process).
Old 06-18-2019, 10:27 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Thanks for answering that as it is something I have thought about from time to time when I go from the TF5 to the UR44.... The UR44 doesn’t sound near as good to my ears. But it is hardy to use from time to time...
Rob
MBP 15” 2018 macOS Mojave 10.14.5 Touch Bar and ID
Pro Tools 2019.6-23.#, Cubase 9.5, Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Does Playback Engine and interface need to be the same? Alexlimbert Pro Tools 12 5 08-03-2017 09:43 AM
ASIO4ALL driver or audio interface driver for playback engine? slidincharlie Getting Started 2 02-26-2017 12:31 PM
ASIO4ALL and the PT10 Playback Engine tpann Windows 4 04-30-2013 02:16 AM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
Playback Engine -- Where's my Disk Playback option? Wheeltard macOS 5 03-16-2012 06:19 AM
