  #301
Old 02-26-2017, 11:12 AM
DC2light DC2light is offline
Default Re: Hackintosh - Salvage your HD PCI cards - You Can Do It Too!
10.8.5 is fine. Current 5xx multibeast works ok but if your using an SSD get trim support elsewhere.
Cheers,
Señior Light
Full Bandwidth 24/7
  #302
Old 02-26-2017, 11:16 AM
Armando Armando is offline
This is all a mute point. If you have a clone drive(which you should) experiment to your hearts content.
Armando
  #303
Old 02-26-2017, 04:52 PM
Niels B Niels B is offline
I use Trim Enabler.
Do you use the Jetway JNAF92-Q67 LGA 1155? No problems with PCI cards or iLok?
Thanks!
  #304
Old 02-26-2017, 04:54 PM
I might buy another mSATA for experimenting and put the one I have now aside.
Are you still using a JNAF92-Q67 LGA 1155?
  #305
Old 02-28-2017, 01:26 AM
Originally Posted by Niels B View Post
I use Trim Enabler.
Thanks!
Yes I have both the Q67 and a Q77. 10.8.5 in both. All good
Cheers,
Señior Light
Full Bandwidth 24/7
  #306
Old 02-28-2017, 08:55 AM
Tanx!!
  #307
Old 02-14-2018, 07:24 AM
zavid zavid is offline
Please guys ,
somebody have built a "issues free" Daw for Windows 7 + Pro Tools 10 HD-HD Accel Pci ,
with some of the mainboard indicated in this thread ?
  #308
Old 02-14-2018, 07:42 AM
Kristo Kotkas Kristo Kotkas is offline
Originally Posted by zavid View Post
Please guys ,
Just go Hackitosh
  #309
Old 02-22-2018, 06:58 AM
Anybody own a free issues Daw with windows 7 and pro tools 10,3,9 - 10,3,10 based on one of the following hardware configurations ?
Originally Posted by jeremyroberts View Post
A hackintosh build for protools HD cards will have the following:
1. case
2. power supply
3. mobo/processor
4. cooler for the CPU
5. GPU (video card)
6. RAM
7. System drive
8. Optical drive
9. Recording drive(s)
10. Sample library drives (if you use VI)
11. backup drive(s)
12. Firewire card
13. eSATA - SATA ports (PCIe card?)
and all necessary wire to connect the dots.
1. The Case. My first big mistake. I failed to consider the HD cards were 12.375 inches long. VERY few mid-tower cases have room for ProTools HD cards. So I originally bought a well reviewed case: Fractal Design Define R3 http://www.silentpcreview.com/fractal-r3
-- but the HD cards simply will not fit. Removing the drive bays was NOT going to be an option for me.
read this:
http://www.silentpcreview.com/Case_B...ecommendations
The MacPro aluminum case is a BRILLIANT design. Quiet. Cool. Sturdy. Clean look. But it does have it's limitations... so the bar is set high. I decided that my build was NOT going to be silent, rather, very, very quiet -- and that opened up many alternatives.
I chose the Antec P280 Black ATX Mid Tower Computer Case. $120
http://www.newegg.com/Product/Produc...82E16811129179
I couldn't be happier!!! Huge case. Lots of room for everything. 13"+ from card rail to the hard drive bay. And it's quiet. As in MacPro quiet. I have the fans at the slow speed.
2. Power Supply. I wanted a power supply with a modular design. I was always annoyed with extra wire that was simply not connected anywhere. I also wanted a relatively quiet model form a reliable manufacturer - and at least 600w. There are "silent" PSUs, and you can spend much more... I think I found a reasonable balance with the SeaSonic M12II 620 Bronze 620W $90
http://www.newegg.com/Product/Produc...82E16817151095
Here's an article worth reading:
http://www.silentpcreview.com/Recommended_PSUs
3. Motherboard. If you want up to 4 PCI slots, this is the one.
JetWay JNAF92-Q67 LGA 1155 Intel Q67 HDMI SATA 6Gb/s ATX Intel Motherboard $200
http://www.newegg.com/Product/Produc...82E16813153216
There is a NEW mobo from Jetway that supports the IvyBridge chip and has USB 3, but until the TonyMac UniBeast and MultiBeast support it, it's not on my radar.
The CPU that works with this mobo is the Intel 2600k. i7, 3.4 ghz. $300
http://www.newegg.com/Product/Produc...82E16819115070
4. CPU cooler. Yeah, you need it. Not to keep the CPU cool, but more to replace the NOISY fan that comes stock from Intel. I didn't do enough research here, but the little research I did pointed me to a very good and almost silent cooler that is quite difficult to install. I bought the ZALMAN CNPS8900 Quiet 110mm Ultra Quiet Slim CPU Cooler $45
http://www.newegg.com/Product/Produc...82E16835118126
But it is a challenge to install...
5. Video Card (GPU). This is the most difficult part to spec, since there are VERY few quiet cards that are compatible with the Jetway and 10.7. -- the problem is many GPUs use the space in the next PCIe slot for the GPU heatsink and fan to live. That is, the card is a double-wide. If you have no intention of using the x4 PCIe card, then you have many options -- but I am using all the slots. So I needed a card that could drive 2 DVI monitors at 2560x1600, and only use 1 slot. And not have a loud fan. I chose:
EVGA GeForce GT 520 1024MB DDR3 $50
http://www.microcenter.com/single_pr...uct_id=0366484
PLEASE READ this very important post at TonyMac about compatible GPUs:
http://tonymacx86.blogspot.com/2012/...x-and-5xx.html
6. RAM -- it's so freaking cheap now. $200 for 32GB. Just get 32gb. I bought a "low profile" chip that allows the CPU cooler to clear. I would avoid the ram with "memory cooling heatsinks" since it will probably get in the way of your CPU cooler. I bought GeIL Black Dragon 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10660) $200 - and it came with a free 32GB USB flash as well.
http://www.newegg.com/Product/Produc...82E16820144565
7. System Drive. RUN, do not walk, and get this mSATA SSD. 120gb. If you haven't done an SSD system drive yet, now is your opportunity. I am booting to Lion in about 4 seconds. mSATA is incredibly cool - it mounts on the motherboard UNDER your PCI cards. I chose the latest and greatest mSATA - and I would get this part again in a heartbeat! Mushkin Enhanced Atlas Series MKNSSDAT120GB-DX mSATA 120GB SATA III MLC Internal Solid State Drive (SSD) $145
http://www.newegg.com/Product/Produc...82E16820226320
8. Optical drive. CDs are not dead yet. I bought a PLEXTOR Internal DVD Super Multi 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM Black SATA Model PX-L890SA LightScribe Support. You can get a less expensive part -- but I have been using Plextor for 20 years. Habit. $38
http://www.newegg.com/Product/Produc...82E16827249071
9. Recording drives. This is your business... but you now have SATA II and SATA III ports -- but come back to this after we go over the SATA ports...
10. Sample library drives. You want SSDs and you want the newest, fastest, SATA III (6gbs).
11. Backup drives. Don't not put these in.
12. FireWire card. NOT for production - but for file transfer. I found the SYBA Low Profile PCI-Express 1394B/A Firewire Card Model SD-PEX30009 works great "OOB" - out of the box. An important distinction for hackintosh builders. If you can get an OOB vs. not, et the OOB. $28
http://www.newegg.com/Product/Produc...82E16815124072
13. eSATA and SATA card. I have yet to spec this for my rig, but that's my project for next week.
OK -- I have my parts. Now What?
You need a few more things:
1. You must OWN your copy of mac OSX Lion. Buy it from the App store, and download the LATEST version (10.7.4) as a new installer file. Just because you already have a lion 10.7.1 installer - that's not going to help you. Download 10.7.4 fresh, but don't allow it to launch. Just download it.
2. You need (2) USB flash drives. Get 8gb or larger. They cost $6 each at Microcenter.
3. Prepare your "UniBeast" - this is the magic tool to install Lion on your build.
http://tonymacx86.blogspot.com/2011/...ion-using.html
Just RTFM and do what it says.
4. Download MultiBeast and put it on the same USB as the Lion install
http://www.tonymacx86.com/viewforum.php?f=125
At this point, you should watch a few videos:
http://tonymacx86.blogspot.com/2010/...ibeast-20.html
5. You probably should download and prepare a DOS boot USB with the flash utility for your mobo BIOS. Ah -- the scary part! I'ma mac guy - what do I know about BIOS? Well, you need to know that you have to change a few settings to make this work. And you need the latest firmware on your mobo -- so download the BIOS from Jetway and a boot USB from a dozen places on the net and flash your mobo.
http://www.jetway.com.tw/jw/ipcboard...name=NAF92-Q67
NOW -- Put Humpty together.
GO SLOW. Be careful. RTFM.
DO NOT put your protools cards in yet. But it's ok to install the ram.
Don't install your mechanical drives. Do this slowly and systematically.
When you are ready to power-up, you will need to adjust your BIOS at first boot -- now is probably the time to verify the BIOS version, flash it if needed, and then adjust some BIOS settings...
Bios settings
Advanced Menu
PCI PME Wakeup S3
CPU Configuration, Hyper Threading---> Disable
All Com ports, Parallel port, CIR Controller---> Disable
SATA Mode---> AHCI Mode (SUPER important!)
Chipset Menu
Initiate Graphics Adapter PEG/IGD
You can't really mess this up, since you can always RESET BIOS to default.
Time to load Lion onto your mSATA system drive?
BOOT from the USB flash (UniBeast)
Follow the guide...
Did I say RTFM and do EXACTLY what UniBeast instructions say?
Then run MultiBeast and install network tools kext. Choose the hnak's AppleIntelE1000e Ethernet. Install it. You're now good to go.
There are a few details that you will quickly pick up. BUT ------
When you are done, you will spend less than $1200 for a box that will run PT HD 10.2 in Lion 10.7.4 and you can use your HD cards.
The $1200 does not include recording drives or sample storage -- for me, this was about preserving value in the HD cards while waiting for AAX dsp plugs. Would I build a hackintosh for PCIe cards? Not sure. And obviously, a new 12-core is a much faster machine. Can we hackintosh a dual-CPU mobo? Maybe. But it would not be nearly the cost benefit of the single CPU i7 PCI - built to use the HD cards we already own.
I delivered a track today that would have been suicidal on the older rig. 90+ voices @ 88.2k. 20+ VSL instruments (VEPRo 5). Used about 20gb of ram. And the machine never went past 50% CPU. ProTools OTOH was complaining all the way. PTHD is not built for 90 voices at 88.2k. But HDX is, right? OK, bring on PT11 and I'll turn this box into a server. But for now, I have a STABLE, rock solid and quiet box. And I feel like I received VALUE for my investment. I would do this again.
Yes, you can do it too!
next post: eSATA/SATA and SSD drives - coming soon (but I need input speccing the right card).
  #310
Old 01-17-2023, 05:18 AM
Hi to everybody
got an Hackintosh used that have 3 OS partitions
1 Mavericks , 2 M. Lion ,
unfortunately one of the 3 partitions do not accept the password for access
there is any way to reset password ?
thanks for any help , info , link , about
also in pm.
Hackintosh - Salvage your HD PCI cards - You Can Do It Too! jeremyroberts macOS 2 07-01-2016 09:32 AM
Hackintosh on my rig? Raoul23 Pro Tools TDM Systems (Win) 7 07-01-2011 03:26 PM
Hackintosh Help HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-16-2010 10:45 AM
Get a laptop or salvage old machine?? Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-24-2008 01:28 PM
OT - Salvage a bad DAT - Possible? soundsurfr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-08-2003 12:55 AM
