Closed Thread
Old 07-30-2009, 11:50 AM
Avid's Avatar
Avid Avid is offline
Administrator
Lightbulb Pro Tools 7.4cs10 Updates
Pro Tools 7.4cs10 updates for all versions of Pro Tools 7.4 for Tiger and Windows; and Pro Tools 7.4.2cs4 updates for all versions of Pro Tools 7.4.2 for Leopard are available for download from the Pro Tools CS Updates page in the Support section:
www.digidesign.com/support/csupdates
Pro Tools 7.4 Systems
The following are the current CS Updates for Pro Tools 7.4. Previous installation of Pro Tools 7.4 is required.
Released July 30, 2009:
What's New in These Updates?
In addition to all fixes from previous CS versions, Pro Tools 7.4cs10 includes the following:
HD, LE, M-Powered (Mac & Windows)
Fixed: A play command in Pro Tools may not always engage playback on the first attempt (Item #114517)
  • After a play command, the Play and Stop buttons may flash, however, Pro Tools does not playback. Subsequent tries would allow playback.
Fixed: Cannot open sessions due to PolyVector error (Item #114287)
  • Certain sessions cannot be opened due to the following error: "Could not complete your request because out_of_range: Cmn_PolyVectorImpl::At"
Fixed: Audible drift when using PAL to Film TCE conversion on long audio files (Item #113490)
  • Using the Time Shift Varispeed preset (PAL to Film -4%) will result in a file that drifts over time and runs out of sync with picture.
HD, LE, M-Powered (Windows)
Fixed: Cannot select the number of RTAS processors on a hyperthreading-enabled CPU (Item #114048)
  • When working with a hyperthreading-enabled processor, Pro Tools does not allow selection of the number of RTAS processors in the Playback Engine dialog.
LE (Windows)
Fixed: Pro Tools LE does not launch when connected to a VENUE system via FWx card (Item #113126)
  • Pro Tools LE would hang on "DAE Loaded" while launching when connected via FWx card.
Administrator
Closed Thread
Pro Tools 7.4cs10 updates Tracy Lowery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-05-2009 06:27 AM
Pro Tools 7.4cs10 & 7.4.2cs4 Updates Avid Post - Surround - Video 0 07-30-2009 12:01 PM
Pro Tools 7.4cs10 Updates Avid Pro Tools M-Powered (Win) 0 07-30-2009 11:53 AM
Pro Tools 7.4cs10 Updates Avid Pro Tools TDM Systems (Win) 0 07-30-2009 11:44 AM
Pro Tools 7.4cs10 & 7.4.2cs4 Updates Avid Pro Tools TDM Systems (Mac) 0 07-30-2009 11:41 AM
