Old 03-07-2003, 08:21 AM
David Lamb David Lamb is offline
Default 888 - AES to Tdif, or MADI convertors?
We use 888s. We would like to get audio into a
system that'll only cope with Tdif, or MADI.
Does anyone know of a reasonably cheap way of doing this?
Id there a conversion for the 888 that will give
Tdif out?
As usual, all ideas welcome.
Many thanks,
Davy
Old 03-07-2003, 11:20 AM
fifthcircle fifthcircle is offline
Default Re: 888 - AES to Tdif, or MADI convertors?
Depends on how many channels you want to run... The cheapest and easiest things would probably be to TDIF.
Look at the Otari UFC (now IZ-Radar http://www.izcorp.com/assets/pdfs/UFC%2024.pdf) and the RME audio ADI-8DD (which will give you ADAT, TDIF, and AES conversion http://www.rme-audio.de/english/adi/adi8dd.htm). RME also makes an ADAT to MADI conversion box. (http://www.rme-audio.de/english/adi/adi648.htm)
As you start getting more expensive, there is the Euphonix box that they developed for the System 5 board. That has MADI as well.
--Ben
Benjamin Maas
Fifth Circle Audio
Los Angeles, cA
Old 03-07-2003, 05:24 PM
Branko's Avatar
Branko Branko is offline
You may take a look at these ones.. FriendChip
Branko
Branko Neskov c.a.s.
www.loudness-films.pt
Old 03-07-2003, 10:47 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Hers you least expensive option:
web page
IMDB
Old 03-08-2003, 02:41 PM
Big problem with the IFAE8 is that depending on the version you have, it often truncates 24 bit words. If you want to be assured of passing 24 bits cleanly, you'll need the IFAE8-HR (which costs a couple hundred $$ more).
--Ben
Benjamin Maas
Fifth Circle Audio
Los Angeles, cA
Old 03-13-2003, 03:28 AM
Thanks to you all for the info.
Much appreciated.
Davy
Old 03-13-2003, 09:48 AM
Doug the Brit Doug the Brit is offline
The Euphonix FC727 is ideal for this!
Lot's of other useful format-converting features on board too.
Digi multipin in > MADI out
Doug
"What on earth is the purpose of Pot-Pourri? Looks like breakfast cereal, smells like your auntie!"
HTML code is On
HD MADI Supports Frame Pattern MADI ??? misterGOLD Pro Tools HDX & HD Native Systems (Mac) 2 02-10-2014 11:43 PM
DA88 TDIF Out to 192 TDIF IN Mixing Madness Pro Tools TDM Systems (Mac) 2 11-07-2011 09:31 PM
AVID MADI - connect 2 MADI units? smc917 Pro Tools TDM Systems (Mac) 4 07-25-2011 02:38 PM
TDIF to MADI Question Scott Fahy VENUE Live Sound Systems 6 01-01-2011 09:30 AM
TDIF to ADAT convertors and 192 dropouts Atwiss Pro Tools TDM Systems (Mac) 2 04-23-2003 04:32 AM
