G4 733 long Boot Time
hello all again,
G4 733, 684 meg all else stock Mix+ PT 5.1 my systems was been workin great, about 2 weeks ago, i noticed a 1 to 2 min delay for my Control Panel Bar to come up.. i cant do any activity on the desktop until the CP Bar is up... i have not added or chaged any programs to my system .. Except PT session files... can someone give me a heads up on whats going on ... Thanx Adam StudioOne Recording |
Re: G4 733 long Boot Time
This happened to me when I first installed PT Mix3 5.1.1 on my(at that time) new 867Mhz G4.
Boot up was very fast before installing, 3 Mix cards and ATTO card. After the install, the boot up time was slower then death. I then reinstalled OS 9.2.2(original OS had both OS9.2.2 and OS X on the drive). This seems to have taken care to the boot up time to some degree although I still think it should be quicker. Now I get the grey screen for a while and then the desktop loads then finally the Control Strip, which now loads after a few seconds(before it took about 30 sec. to 1 min.). Anyone else have suggestions to what may be causing the overall slow down?
Armando |
I always disable the Appleshare ext if not needed and I Option open the Memory control panel and turn off Memory check on boot up, with todays big memory systems memory check adds a lot of time to every boot & reboot .... But this might not be your problem,...
AppleShare is certainly a potential problem.
If you're using an iMate USB to ADB adapter, the iMate software can really slow the boot-up process down as it does its time consuming checking. Also, do you have the start-up menory test disabled? This would help speed things up. Lee Blaske |
In case you don't remember how to uncheck memory test at boothup, hold option command while selecting Memory Control Panel, and at the bottom will appear only for this time an option to uncheck memory test at the boothup.
So just uncheck it and the next time you'll booth your computer, mem. check will be bypassed. [img]images/icons/smile.gif[/img] |
A couple of things I have found that can cause this..is any type of "sharing" file sharing/users and groups..etc..on.
When the machine boots..it starts looking for nodes on the network..etc..and trys to make connections. A bad crash..or..zapping pram..can sometimes reset these settings from OFF to ON. If you have any network setting on...or have used a cross over cable..etc..to hook your mac to a network to transfer files..etc..check and make sure none of these settings are active. Also, the startup disk control panel setting occasionally gets unselected. This also can cause a "search" function at startup that can cause about a 10 second or more delay. Go to your startup disk control panel and make sure that your boot disk is selected (highlighted). The memory test disable saves a couple of seconds on startup..but would not account for the delays you are seeing. Sounds like your machine is searching for a network to me. dcornutt |
The joliet volume acces extensions do heavy havoc on certain (not all) of my machines during startup.. TheToast cd-reader extension seems pretty picky at startup on some machines as well..
Huby |
long PT 8 boot with plugins scan | Sagas | Pro Tools M-Powered (Win) | 13 | 02-09-2011 03:43 AM |
Slow boot-up time PT 8.0.4cs2 on Win 7 - plug-ins load every time | jmac146 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-02-2011 04:49 PM |
1st time caller, long time listener | brill bedroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-23-2005 06:12 PM |
Long, long Time loading PTLE on G4 DP 1.25!! | pockets745 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-30-2004 05:09 PM |
How long does it take to boot up ProTools? | naman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-30-2000 11:25 AM |
