How to \'bus\' ALL tracks receive same insert? PTLE
Can I insert an effect to say 8 tracks (eg Wave Arts FinalPlug) at once? I cannot see a final mixdown in the Mixer panel, nor a bottom combined track in the 'Timeline'. (Am from a film background so I have a weird mindset). It would seem mad to bounce to disk and then apply the required effect in, say, Peak. Am using latest software and MBox with a G5. TIA. (Please explain slowly as it were.)
Re: How to \'bus\' ALL tracks receive same insert? PTLE
Creat an AUX track, set it up the input for the bus you're using, and put the plug-in on the aux track. You can use the the individual bus controls on each track to determine HOW MUCH of the effect you want.
Create a Stereo Master Fader.
Quad 2.5 G5, 4.5G RAM |
However, there is one advantage to the master fader: if you wanted all tracks to have the same insert, same wet/dry mix of the insert and the input level to the insert to follow the track's volume automation, going the master fader route would certainly be the simplest way to do it. But even then, you might change your mind about some of those things... |
My response was prompted by 'I cannot see a final mixdown in the Mixer panel', which suggested he didn't know about Master Faders.
Very many thanks for the responses to my query/quandry - it's quite a wonderful resource here. A new perspective opens on PT - I love it even more! Surya
So we gave him two options. Between both of us I'd say we've done our good deed for the day on the DUC! |
New metering for bus' | Solid Sound | Windows | 2 | 02-19-2014 04:09 PM |
Change one insert on a track - change all tracks with same insert | World Spirit | macOS | 6 | 02-22-2012 03:07 PM |
Instrument/MIDI tracks receive all channels - ProjectMix issue??? | jrgwynn | Pro Tools M-Powered (Win) | 2 | 07-03-2010 12:17 AM |
Routing Midi to Aux tracks/Bus' | SergeK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-05-2003 10:58 PM |
Send/Receive Sys Ex with Trinity/PTLE | mfym | MIDI | 1 | 04-02-2001 01:18 PM |
