Old 07-29-2018, 11:26 AM
WernerF WernerF is offline
Default Re: Waves The Abbey Road Chambers AAX
Wonder if it installs on 10.9 Mavericks? Anyone tried it? Have to buy it to find out over here.
Old 07-29-2018, 12:08 PM
TrentWilliams TrentWilliams is offline
Originally Posted by DetroitT View Post
4 Waves Plates/chambers on Aux tracks, HDX 1.
Pro Tools System Usage results on a similar system.
ARC Plates:x4
43 % @ 44.1Khz
61% @ 96Khz
ARC Chambers:x4
74 % @ 44.1Khz
76% @ 96Khz
That’s crazy .. what’s wrong with your system? I laid down 10 instances on chambers on a session yesterday, it only clocked 26% @ 44.1 on a native system ¯\_(ツ)_/¯
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 07-29-2018, 12:56 PM
jjnssn jjnssn is offline
What buffer settings?
Old 07-29-2018, 01:08 PM
You can't get the demo?
Even if you can I doubt the WavesHell you have would allow it to install/work. All I know is the last 9.x WavesHell would not install on Mavericks - had to go to Yosemite.
Old 07-29-2018, 01:54 PM
Thanks Musicman. We have both the TDM stuff and, I think 9.6, installed on Mavericks here. Waves, when we finally got the right tech support guy, talked me through how to do it. It’s not supposed to work but does if you jump through a couple of hoops to do it. Don’t know if the new Chambers will work but we have the Abbey Road Plates installed. Could get the demo even though we haven’t gotten any new Waves stuff in quite awhile just to avoid the hassle of going through the install process again.
Old 07-29-2018, 08:34 PM
DetroitT's Avatar
DetroitT DetroitT is offline
1024 (2048)
256 is the lowest I can go. Solid though.
Old 08-15-2018, 02:09 AM
Originally Posted by toolz View Post
It installed fine on Yosemite, but I chose to not update any of my other Waves plugs.. it runs quite badly at 96k, but pushing the buffer to the largest, its ok to audition and commit.
Certainly my new favourite reverb, and worth every cent.
That's a bit scary, because 96k is my go to session sample rate. Hopefully it will fair better once I put it to work.
Old 09-03-2018, 11:14 AM
PatriotsBiker PatriotsBiker is offline
I tried this out, liked it and purchased it. I also tried the PRS amps set and enjoyed for the most part. I put Chambers in after finding a decent low-gain patch on the "Dallas" amp. This combo was nice. It gave me some nice Gilmour and Knopfler style vibes. I still need to dial Chambers in better.
Performance-wise, it did not enjoy being part of a deep linear chain. I was testing from within a Session I already had open, so I just created my normal ITB amp sim chain. Mono track for the guitar signal feeding into an Aux track with the amp-sim, and a 3rd track where I "print" the output for easier processing. A habit I got into with weaker computers. Anyhow, this did fine going straight to the master out. When I sent it into the chain I had set up for the actual Session, the system usage meter jumped from the high 20's up to the high 70's. (fwiw - The rest of the chain was a bus each for guitars, mix and a test mastering bus before hitting the master out with only a peak limiter engaged. The three busses have 3-4 plugs each going.)
Old 09-03-2018, 05:37 PM
joeydego's Avatar
joeydego joeydego is offline
although a little ticked over the fact I already own the abbey road "collection", not "bundle", chambers wasnt included at the time. That being said, for 29 bucks it sounds great.
2012 mac pro PT 2018 Presonus Studio 192
Old 09-03-2018, 09:57 PM
DetroitT's Avatar
Say no more. Liic$Nstuff
$29 soundset.
HTML code is On
Abbey Road reverb mikeyman Tips & Tricks 5 03-29-2018 02:17 AM
Abbey Road Reel ADT crandallwarren Buy & Sell 0 06-19-2017 07:25 PM
WTB: Abbey Road Rs-124 Plugin ronzie Buy & Sell 2 12-14-2014 08:18 AM
Abbey Road Plugins guatamas AAX Plug-ins 2 04-11-2013 06:59 AM
OT: Abbey Road related RadioMoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-07-2005 08:11 AM
