Old 08-10-2013, 08:41 PM
Mdubbs818 Mdubbs818 is offline
Default Speaker Noise only when PT launches
Hello all,
First time poster. Running PT 9.06 on OS 10.7.4 (Hackintosh). Finding a consistent issue where my speakers (pair of M Audio BX8s) will start making a low level white noise whenever I launch Pro Tools. If I play audio from any other application (Finder, quicktime, iTunes, etc.), no white noise is present. As soon as I launch Pro Tools, the white noise kicks in and is persistent until I quit the application.
I am running a 3.5mm stereo to XLR cable from the analog port (green) to the speakers. Like I mentioned, all other audio plays fine, it only occurs when I launch Pro Tools (which to me rules out a grounding issue or a problem with the speakers).
Any thoughts on the matter would be appreciated.
Thank you,
~ MW
Old 08-11-2013, 04:29 AM
Default Re: Speaker Noise only when PT launches
Originally Posted by Mdubbs818 View Post
Hello all,
Thank you,
~ MW
What do you mean by 'analog port (green)'? Are you talking about some kind of connector on your computer which I guess means you're using the computer's internal audio output? If you are you do know those types of connectors (3.5mm aka 1/8 inch) do not have balanced connections right? That's what you really should have, along with a proper audio I/O interface. It's not the application (PT) with the problem - it's your hardware. Motherboard audio is NOT meant for much other than simple stuff like iTunes or system sounds; I wouldn't even use it for games.
I know your monitors supposedly will work with unbalanced connections but those are not good for low noise applications like recording/monitoring.
Jack
QAPLA!
1kHz PC & Speaker Noise - HELP!!! dbooth Windows 17 09-14-2014 08:50 PM
Weird Noise Through Speaker... VTI Pro Tools M-Powered (Win) 2 08-31-2011 03:43 PM
Control 24 speaker noise problem dvodesilva ICON & C|24 4 12-26-2009 06:09 AM
weird (not white noise) in right speaker in any app paul5mq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-12-2009 02:13 PM
Digi 002 Speaker Noise tubestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-09-2004 11:28 AM
