Old 07-11-2018, 11:23 AM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default macOS 10.13.6 with 2018.4
I know it was just released. Did anyone the plunge? If so, how are things running?
Old 07-12-2018, 09:05 PM
mattrixx mattrixx is offline
Default Re: macOS 10.13.6 with 2018.4
Justy fine here. 2013 MacPRO and 2017 Macbook Pro
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 07-13-2018, 01:07 PM
zerodistraction zerodistraction is offline
Working fine here with 2018.4. Use at your own peril though as our hardware and plugin configs are different. Personally I’ve never had issues with patching macOS. It’s only jumping from one major version to another where serious problems can happen. Maybe I’m lucky.
Old 07-21-2018, 11:42 AM
VRW VRW is offline
+1
No problems here as well.
2014 Macbook Pro i7 Quad, 16GB Ram, Apollo Thunderbolt series 1, UA Octo Satellite, macOS 10.13.6, Pro Tools 2018.4 HD+Native
Old 07-23-2018, 10:46 PM
TNM TNM is offline
Ok, since you guys have no issues, may I at least ask what latency you are running?
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX
Old 07-25-2018, 10:33 AM
I generally run at 256 when tracking.
Old 07-25-2018, 11:40 AM
ktmcgraw ktmcgraw is offline
I did. Now I'm having latency while recording even though low latency monitoring is turned on. While recording I can get it to stop by turning low latency off and back on again, but every time I hit record there's latency again. No good. Anyone have a solution?
Old 07-25-2018, 02:24 PM
DetroitT's Avatar
DetroitT DetroitT is offline
"... every time I hit record there's latency again. No good. Anyone have a solution?"
Does your Master fader have zero plugins?
Old 07-26-2018, 02:39 AM
Bfrink1971 Bfrink1971 is offline
It appears to be a bug.
http://duc.avid.com/showthread.php?t=396670
Try turning quick punch on and then off again. This seems to fix the problem for me, at least until I arm another track for record.
OS 10.13.5 - will PT 2018.4 or .5 work well or stay with 2018.13? blankpro Pro Tools 2018 4 07-11-2018 07:22 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Weird UI glitches in 2018.3 on macOS 10.13.3 Chingy Pro Tools 2018 6 04-06-2018 05:17 AM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Sluggish Zoom in/out + scrub issues 2018.1 (MacOS 10.13.3) Hrmonik Pro Tools 2018 0 01-28-2018 10:35 AM
