Old 11-20-2008, 03:39 AM
digidesigner digidesigner is offline
Default cant import data - no access privileges??
Hi!
I am seriously confused... I have two sessions on different drives that open up just fine by themselves. First has drums and the other one has all the rest for a song. If I try to import the data from a session with drums into the later session with everything else I get blank regions on the tracks and error that says error processing audio files - you do not have necessary access privileges (-5000)
I am on mix system PT 6.4.1, osx 10.3.9
Old 11-20-2008, 07:36 AM
aux aux is offline
Default Re: cant import data - no access privileges??
Check the privileges for the Audio Files and the session folder (both source and destination) you're trying to import. See if they are the same as the current Mac OS user.
Aux
MassiveMusic
SOS article
...do not have appropriate access privileges ifix macOS 13 03-20-2017 12:30 PM
Import session data - access violation Boe Larsen Pro Tools TDM Systems (Mac) 34 08-18-2016 02:03 PM
Do Not Have Appropriate Access Privileges?! :( Alexander4444 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-20-2010 07:47 AM
Access Privileges Chris King Pro Tools TDM Systems (Mac) 1 05-14-2005 07:42 PM
Access privileges colnago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2004 06:39 AM
