Pro Tools HD 7.2cs3 & HD 7.2.1cs3
Now available from the Pro Tools CS Updates quick link in the Support section:
http://www.digidesign.com/index.cfm?...4&itemid=23300 and the Download and FAQ sections for relevant products: Pro Tools HD 7.2.1cs3 for Apple Mac Pro http://www.digidesign.com/index.cfm?...4&itemid=25016 Fixed: Adjusting Send Levels While Recording Audio Can Result in the Send Levels Resetting to "0" When Reopening The Session (Item #86186) - This would occur if no automation had been written on the Send. Fixed: On Intel-Based Macs, Snaps and Distortion Could Result When Using CoreAudio (Item #83316) Pro Tools HD 7.2cs3 for Mac OS X (PowerPC) http://www.digidesign.com/index.cfm?...4&itemid=25017 Fixed: Adjusting Send Levels While Recording Audio Can Result in the Send Levels Resetting to "0" When Reopening The Session (Item #86186) - This would occur if no automation had been written on the Send. Fixed: Disabling "Auto Input Monitoring" on Logic Pro 7.2.x with DAE Results in Random Error Messages (Item #85250) - This problem does not occur with "Auto Input Monitoring" enabled - Note: Logic Pro DAE configuration is only available with Logic Pro on PowerPC-based Macs. Logic Pro DAE configuration on Intel-based Macs is not yet available Pro Tools HD 7.2cs3 for Windows XP http://www.digidesign.com/index.cfm?...4&itemid=25018 Fixed: Adjusting Send Levels While Recording Audio Can Result in the Send Levels Resetting to "0" When Reopening The Session (Item #83793) - This would occur if no automation had been written on the Send. Fixed: Error with message "Digidesign CD Ripping Service using SPTI has encountered a problem and needs to close". (Item #85536) - This could occur if there was a CD in the computer when opening the Workspace Browser. Dismissing the dialog sometimes caused a freeze or unexpected quit. Fixed: Moving OMF Video Clips On The TimeLine Could Result In an Access Violation Error Message (Item #85536) - This would usually occur if a number of drag and dropped OMF video clips from the Workspace were moved around on the timeline. The message was "Could not complete the Region Slide command because Access violation occurred".
Administrator Avid Pro Audio Community |
Pro Tools 7.4.2cs3 & 7.4cs9 Updates | Avid | Pro Tools M-Powered (Mac) | 0 | 03-31-2009 07:36 PM |
Pro Tools 7.4.2cs3 & 7.4cs9 Updates | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-31-2009 07:27 PM |
Pro Tools 7.4.2cs3 & 7.4cs9 Updates | Avid | Pro Tools TDM Systems (Mac) | 0 | 03-31-2009 07:23 PM |
Pro Tools HD 7.2cs3 Update | Avid | Pro Tools TDM Systems (Win) | 0 | 05-02-2007 07:09 PM |
Pro Tools HD 7.2cs3 (PPC) & 7.2.1cs3 (Intel) Updates | Avid | Pro Tools TDM Systems (Mac) | 0 | 05-02-2007 07:06 PM |
