Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 03-09-2007, 01:23 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.3.1cs2 Updates for All 7.3.x Systems
Available for download from the Pro Tools 7.3 and core system downloads sections, and the Pro Tools CS Updates quick link in the Support section:
http://www.digidesign.com/index.cfm?...4&itemid=23300
Pro Tools 7.3.1cs2 Updates for Pro Tools 7.3 & 7.3.1 Systems - March 8, 2007
Area: DigiBase preview
Mac and Windows Pro Tools HD, LE, M-Powered, and Academic
Fixed: Previewing Audio in the Workspace Could Cause an Assertion Error (Item # 87627)
- This would occur if the previewed audio was the result of a search. Note that clicking on the waveform was not problematic.
Area - creating memory locations
Mac and Windows Pro Tools LE, M-Powered, and Academic
Fixed: Under Certain Circumstances, Creating New Memory Locations Could Cause an Unexpected Quit (Mac) or Access Violation Error (Windows) (Item #87164)
- This would occur if the preference "Default Region Color Coding" was set to "Marker locations."
Area: ICON
Fixed: ICON Faders Can Become Offset From the Pro Tools Level (Item #87717)
- This could occur if the fader was moved without receiving a "touch on" and then touched properly.
- Note - After installing Pro Tools 7.3.1cs2, the user must un-declare, then re-declare the ICON main units and fader packs to prompt the firmware update dialog. If the ICON firmware is not updated, the fix will not be installed.
Area - Plug-in editing on the 003
Fixed: The Parameters and Values in the Display Bar Could Be Focused on the Wrong Plug-In (Item 85007)
- After focusing to a new plug-in, the top row of the scribbles would reflect the new plug-in, but the bottom row display and controls would continue to be focused on the previously selected plug-in.
Area: Mbox 2 Pro
Mac Pro Tools LE
Fixed: Upon First Playback, DAE -6085 Error With Mbox 2 Pro (Item # 83789)
- The workaround was to unplug/replug the Mbox 2 Pro after booting the computer
Administrator
HTML code is On
Pro Tools 7.3.1cs2 Updates for All 7.3.x Systems Avid Pro Tools M-Powered (Win) 0 03-09-2007 01:40 AM
Pro Tools 7.3.1cs2 Updates for All 7.3.x Systems Avid Pro Tools M-Powered (Mac) 0 03-09-2007 01:38 AM
Help Pro Tools 6.4.1cs2 Update for MIX Systems TommyT Pro Tools TDM Systems (Mac) 1 01-25-2005 04:43 PM
Pro Tools 6.4.1cs2 Update for MIX Systems Avid Pro Tools TDM Systems (Mac) 21 01-14-2005 01:18 PM
Pro Tools 6.4.1cs2 Update for MIX Systems Avid Pro Tools TDM Systems (Win) 0 11-23-2004 01:05 PM
