  #41
Old 05-24-2019, 06:03 AM
Default Re: Artist Mix EuCon 19.5
Originally Posted by EddieJones View Post
Are you on PT 19.5 ?
I am. The plugin windows not following bug has now been reported to support by a colleague. There should be a case about it with screen grabs, videos etc.
The font sizes I have manually fixed.
PTHDn 2019.5 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
  #42
Old 05-24-2019, 09:29 AM
Muzoid Muzoid is offline
I'm having these same issues in PT 2019.5 / 19.5 Eucon / Mojave, and was having all of these issues in the last version of PT under High Sierra.
Also... I'm having an issue where I insert a send on a channel and when I try to adjust the send (in flip mode, not sure if it'll do the same when not flipped), the fader will not adjust the send or vice versa. very annoying and this controller is starting to be unusable. Channel shows that there is a send on the channel but acts like there isn't.
  #43
Old 05-27-2019, 07:31 AM
If you need Eucon, I would go back to the last version
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Eucon sees my Artist Mix as an MC Mix TheDavidLim Artist Series 1 11-29-2016 09:42 PM
Artist Mix/Eucon Problem digitalpapaya Artist Series 0 04-19-2016 12:44 AM
Artist Mix with Eucon 3 very sluggish mrtomcat Artist Series 0 10-02-2013 11:43 PM
Artist Mix freezed , Eucon 2.62 peterle Artist Series 4 09-11-2012 08:32 AM
