Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 01-25-2015, 02:51 PM
Bearchild1623 Bearchild1623 is offline
Default Trouble Running Pro-Tools Express
So, I can't seem to start up my Pro Tools as every time I try I get a message that says "Procedure Entry Point Not Found" and then it closes down.
It used to work fine but instead it's just that message now.
I have tried uninstalling and reinstalling a few times but with no success. I have searched the internet for an answer and either no solution works or I don't understand the answer (I'm not very clever with technical stuff).
Anyway, this is message I get when I try to start it up. Any ideas on how to fix this?
Old 01-26-2015, 06:52 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Trouble Running Pro-Tools Express
The error you are getting is because Pro Tools can't load another piece of software it needs in order to run. I really can't tell what that component is from the error message, but something must have changed.
From the screen shot, it looks like that computer is used for more than just Pro Tools, so is there any program that was just installed or updated?
You may either need to remove whatever was just installed, or you will need to uninstall and reinstall Pro Tools.
Will
System Details
Old 01-26-2015, 07:24 AM
justus1900 justus1900 is offline
IM not sure what the problem is but the worst thing in the world you can do when trying to run Pro Tools on a computer is have McAFee Anti Viris installed on the same computer.
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 01-26-2015, 08:03 AM
Michael Zull Michael Zull is offline
Correction, the worst thing in the world you can do to a computer AT ALL is to have Mcafee installed.
Old 01-28-2015, 09:58 AM
I had also installed Superior Drummer too, could that have somehow caused this?
I've tried uninstalling and reinstalling Pro Tools, it doesn't solve it.
Also, why is MacAfee bad to have?
Old 01-28-2015, 10:02 AM
I dont think you can use 3rd Party Plug-Ins with PT Express so yes Superior Drummer that could be the problem.
Main:
JBL LSR4328P 8"
Old 01-28-2015, 10:06 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Pro Tools Express can use RTAS, AudioSuite, and 32-bit AAX plug-ins, Avid or 3rd party.
The older Pro Tools SE could not use plug-ins not included with Pro Tools SE.
Bruce Paine
System Details
Old 01-28-2015, 10:51 AM
Could it be that I'm using a 64 bit operating system while PT Express is only 32 bit?
Old 01-28-2015, 11:11 AM
No, that is irrelevant, 64 but OSes run 32 bit applications just fine. But make sure you are using a supported OS version.
Old 01-28-2015, 11:44 AM
Okay cheers, I wasn't convinced that was the problem anyway. Do you think the best thing to do would be to just phone Avid?
Trouble downloading Virtual Instruments Express... krm27 Pro Tools Express on Windows 2 04-18-2014 12:08 PM
How To: Get PT-Express running on Windows 8! yeenar Pro Tools Express on Windows 0 06-18-2013 12:44 AM
Trouble running PT LE 6.4 on Powerbook G4 eastor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-23-2006 06:18 AM
anyone running pci express hd core? patricia Pro Tools TDM Systems (Mac) 1 01-25-2006 04:03 PM
