Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 01-22-2018, 12:12 PM
Pinball Wizard Pinball Wizard is offline
Default Omni and Izotope RX without PT?
I am using an Omni and an HD Sync with Pro Tools HD native. I am on Windows 10 with an old, but previously Avid qualified HP Z400. I do have a Digilink license. All is working fine.
I would like to use the Omni to get audio into the computer for other software. Specifically, I would like to get audio into Izotope RX 6 without using Pro Tools. There are many threads here about getting audio OUT of an Omni, but that is not what I want to do.
Yes, I do know about RX connect and that does function as a work-around. Yes, I do know about RX Monitor and that also doesn't completely address this.
I also know about the ASIO Avid driver in RX preferences. I suspected that may be the solution but it didn't seem to help when I tried it. I really don't know much about it.
Has anyone here been able to get this to work?
Thank you.
Main Workstation: Pro Tools 2023.12.1, Windows 11, HP Z4 Xeon 8 core W2145, 64 GB DDR4, Omni, Artist Mix, Sync X, Eleven R(2 of them), UAD 2 PCIe card
Old 01-22-2018, 08:44 PM
Default Re: Omni and Izotope RX without PT?
First off, is Windows set(in Sound>Properties) to use HDN/Omni as its default playback device?
The vast majority of Windows systems are best off with Windows set to use the computer's on-board sound card as the default playback device. So with that in mind, could you take an optical SPDIF output from the motherboard and connect that to a matching input of the OMNI and then use the Omni's monitoring function(its SUPPOSED to allow any input to be monitored).
Old 01-23-2018, 09:35 AM
Thank you for taking the time to read and reply to my question.
Please understand that I am trying to get audio IN to RX and, of course I am talking about RX stand-alone, not when used as a plug-in.
No, I do not see the Omni as a choice for the Windows device. ...and that of course is my problem.
The Z400 does not have motherboard digital connections.....only analog. I guess that I could use a sound card but I am really hoping to essentially use the Omni and Avid Dgilink card as a soundcard.
So perhaps a better question might be.....
Windows users: does the Omni show up as a choice in Windows control panel for default input/output device?
Again, thank you.
Old 05-29-2018, 03:38 AM
Just got RX6 and it's pretty amazing. For standalone I had to go into the preferences for RX and select my audio interface (Avid 11 Rack) for the ins and outs. Should be the same for Windows I would imagine.
Old 05-29-2018, 12:12 PM
Is the OMNI available under Sound Properties>Recording? You could also record into Pro Tools session and then Drag&Drop the audio from the session Audio Files folder, directly into RX
Old 06-21-2018, 03:47 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Source-Nexus (if you were mac) allows you to pipe audio around your programs.
I am sorry I do not know of a windows equivalent.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Izotope RX Loudness and Izotope Insight: Worth the purchase? Piano Pete General Discussion 3 01-04-2017 09:52 PM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
