Old 05-25-2001, 08:12 AM
layman layman is offline
Default Tempo change without pitch change for audio
I am new to using 001 and can't seem to figure out if it can alter the tempo of audio tracks without altering the pitch. I found how to alter MIDI data, which was no problem, but the same process did not work for audio.
I am in a rush to get some songs out and need to speed up or slow down some of them> I think I may scream. Maybe 001 doesn't do this, I can't find any help in the documentation so anybody's input would be greatly appreciated.
Old 05-26-2001, 12:28 AM
PAM PAM is offline
Default Re: Tempo change without pitch change for audio
Just to clear something up, the 001 is hardware ie. it dosen´t do much without software ie. Pro Tools.
Your problem is not the 001 but the software you use to "drive" the 001..
And now to your problem:
Try to get hold of a copy of Sonicfoundry ACID it´ll do the job for you, and it´ll run on your 001.
- get a free demo on www.sonicfoundry.com for a start.
Hope it helps
PAM
MOCN - Euro-Sound Studio
Old 05-26-2001, 12:44 AM
Rock_Artist Rock_Artist is offline
If you need superaccurate system with high quality try the Pitch'n'Time Audiosuite (PT Plugin) you can purchase it... look at the site.
This tool is unbelievable and... cost money
Just wanna do music,
RA.
Old 05-27-2001, 12:56 AM
BwanaR BwanaR is offline
Have you tried Time Compression/Expansion under ProTools AudioSuite? I believe this may be what your looking for.
Old 03-16-2002, 06:33 PM
Sharkcellar Sharkcellar is offline
BwanaR [img]images/icons/confused.gif[/img] Your suggestion was admirable but lacking of any real information. I am in the same boat. The problem with the Audiosuite plugin Time Compression/expansion is that there is no support telling one how to actually use it effectively. I've tried getting some samples to change length but not pitch and I only come up with Chimpunks or Lurches. Can someone who's really dug into this program provide some genuine advice please. Thanks.
[email protected]
OS - XP Pro SP2
Video Card - Nvidia GeForce 6600
Audio Interface:
- Digi001 - ProTools LE 6.4
- Audiophile 2496
Motherboard - Intel D915PBL
Old 03-16-2002, 07:14 PM
Mr_Seven Mr_Seven is offline
The Audiosuite Time Compression/Expansion is pretty straight forward. First select the region you'd like to affect choose the plugin and set your parameters. Use caution to make the settings minimal, otherwise it can end up sounding a little weird.
Darren Valen
Cyberdream Studios
Best quality pitch tempo change juliandb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-13-2010 01:50 PM
How do you change the pitch (key) and tempo on Mbox 2? Tool Tips & Tricks 3 02-16-2008 09:33 AM
Pitch/Tempo Change when opening a session blackstarmusic85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-27-2007 02:34 PM
What plug-in will change a loop's tempo but not it's pitch? in10shun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-01-2003 04:51 AM
Tempo change without changing pitch? Styles Bitchly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-05-2002 03:02 PM
