Pro Tools has stopped working
I have a problem every time I open Pro tools and try to create a new session. If I create a blank session or use a template, it's the same.
PT crashes when it gets to 'Restoring Tracks...' and the 'pro tools application has stopped working' message pops up with the following details: Problem Event Name: APPCRASH Application Name: ProTools.exe Application Version: 10.1.2.46 Application Timestamp: 4f7bf690 Fault Module Name: MSVCR80.dll Fault Module Version: 8.0.50727.6195 Fault Module Timestamp: 4dcddbf3 Exception Code: c0000005 Exception Offset: 000172d7 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 3081 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 It's a fresh install of PT updated to 10.1.2, so no additional plugins installed. I haven't even installed the instrument packs or any extras yet. Any help would be appreciated. Cheers |
Re: Pro Tools has stopped working
Did it work previous? What version? Sandra Report?
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Yes, it worked on version 10 fresh install and, sorry but I have no idea what a sandra report is.
EDIT: Found out what a Sandra report is: SiSoftware Sandra ID Host Name : HAL-9000 Workgroup : WORKGROUP Computer Model : OEM To Be Filled By O.E.M. Serial Number : To Be Filled By O.E.M. Chassis : OEM Desktop Mainboard : ASRock P67 Pro3 SE BIOS : AMI (OEM) P1.20 06/22/2011 Intel vPro : 7.01.10.1065 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (4C 8T 3.79GHz Turbo, 3.8GHz IMC, 4x 256kB L2, 8MB L3) Chipset Memory Controller : ASRock Core (Sandy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : Nanya M2F4G64CB8HB5N-CG 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Nanya M2F4G64CB8HB5N-CG 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Nanya M2F4G64CB8HB5N-CG 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Nanya M2F4G64CB8HB5N-CG 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : NVIDIA GeForce GTX 580 (512 SM5.0 1.57GHz, 3GB 4GHz 384-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTX 580 (512SP 16C 1.57GHz/1.54GHz, 3GB 4GHz 384-bit) Compute Shader Processor : NVIDIA GeForce GTX 580 (512SP 1.57GHz/1.54GHz, 3GB 4GHz 384-bit) CUDA GP Processor : NVIDIA GeForce GTX 580 (512SP 16C 1.57GHz/1.54GHz, 3GB 4GHz 384-bit) Storage Devices Corsair Force 3 SSD (120GB, SATA600, SSD) : 112GB (C:) WDC WD10EARX-00N0YB0 (1TB, SATA600, 3.5") : 932GB (D:) Hitachi HDS721010CLA332 (1TB, SATA300, 3.5", 7200rpm, 29MB Cache) : 932GB (E:) ChipsBnk Multi-Reader (USB2) : N/A (G:) Canon MG8100 series (USB2) : N/A (H:) ATAPI DVD A DH20A3S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices System Reserved : 100MB (NTFS) DataDisk1 (D:) : 932GB (NTFS) @ WDC WD10EARX-00N0YB0 (1TB, SATA600, 3.5") DataDisk2 (E:) : 932GB (NTFS) @ Hitachi HDS721010CLA332 (1TB, SATA300, 3.5", 7200rpm, 29MB Cache) Hard Disk (C:) : 112GB (NTFS) @ Corsair Force 3 SSD (120GB, SATA600, SSD) Removable Drive (G:) : N/A @ ChipsBnk Multi-Reader (USB2) Removable Drive (H:) : N/A @ Canon MG8100 series (USB2) Optical Drive (F:) : N/A @ ATAPI DVD A DH20A3S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASRock P67 LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASRock Cougar Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : nVidia GF110 High Definition Audio Controller Audio Codec : nVidia Riva 128 Graphics Accelerator [NV3] Audio Codec : nVidia Riva 128 Graphics Accelerator [NV3] Audio Codec : nVidia Riva 128 Graphics Accelerator [NV3] Serial Port(s) : 1 Disk Controller : ASRock Cougar Point 6 port SATA AHCI Controller USB Controller 1 : ASRock Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : ASRock Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : ASRock Etron USB 3.0 Extensible Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon MG8100 series Printer XPS (USB, Colour) Printer : Canon MG8100 series Printer (USB, Colour) Printer : Adobe PDF Converter (4000x4000, Colour) Scanners and Cameras Scanner : WIA Canon MG8100 ser (Scanner, USB) Peripherals Network Services Network Adapter : Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.20) (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 7.6 |
Yep, done all that and I'm using a Phonic Firefly 808U.
I've uninstalled then reinstalled ver. 10 without the updates and it's working fine again, so I'll just stay with that for now and hopefully will be able to figure out what the problem is then I can update. cheers |
Does anybody have a good-working P67 setup?
Pro tools has stopped working | hellbert | Windows | 1 | 04-12-2011 07:09 PM |
pro tools has stopped working | armando80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 30 | 10-10-2010 12:33 PM |
Pro-Tools has stopped working! | sonicawd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-09-2010 05:29 PM |
Pro Tools Stopped Working | armando80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-24-2009 08:22 AM |
Pro Tools Application has stopped working! | myklmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-30-2009 05:03 PM |
