I/O Settings and routing
Hello,
I need a best practice advice. I often record live shows or on location stuff using PT combined with Dante. Then I mix in the studio. When I open the session in the studio the I/O settings reflect the recording gear and not the studio routing. So here is what I do: Setup/ IO settings delete the bus config and hit the default. But then I need to change the I/O on each and every track. Is there not a simpler way to achieve this? Import Session data minus the I/O ?? Template session and then import audio only? I have to admit that the I/O Settings have been a mystery for me for the past 10 years :) Thanks
Thanks very much Georges The Saxplayer |
Re: I/O Settings and routing
Create a mix template.
Import your session data from your record session into your mix template (you can create an import session data preset that excludes I/o to recall each time) Bonus points for using the same track names in both the record and mix templates so you can use match tracks to make the whole process only take a few seconds.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Sounds good! Thanks
The only thing with the mix template matching tracks is that what I record is so diverse that a drum bass-key-guit-voc setup will only work in 5% of the cases :)
Just have your Mix template with all the tracks you could possibly use. Then make them all hidden and inactive (this is for only your audio tracks). Then when you import session data from the record session, make sure track state is imported. That will then cause only the tracks you are currently using to become unhidden and active. And so you have a nice clean session to start your mix.
Output routing settings for speakers without sound card | Kurout | Pro Tools 12 | 4 | 12-21-2017 10:39 AM |
Copy settings, paste settings ? | Terry Wetzel | General Discussion | 6 | 04-03-2016 06:13 AM |
Can can you save bus settings/routing as a snapshot? | shnurgle | Pro Tools TDM Systems (Mac) | 10 | 04-30-2009 03:50 PM |
Pro tools click settings (1/8 notes or 16th note settings )? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2008 09:59 PM |
Cannot save plug-in settings to Root Settings folder | SimonORorke | Pro Tools M-Powered (Win) | 1 | 01-18-2008 08:38 PM |
