Old 12-06-2019, 08:56 PM
ozzlvlosis ozzlvlosis is offline
Default Two iLoks 1 license
I use Pro Tools 11 on my laptop at work when i'm not home. It's becoming a pain to keep switching the ilok between my home desktop and laptop. Is it possible to have 2 iloks with the same Pro Tools license?
Old 12-06-2019, 09:11 PM
Sardi Sardi is offline
Default Re: Two iLoks 1 license
No it’s not.
If you upgrade to a current version you could take advantage of the iLok cloud authorisation option and that way, you can just have the license in use without the physical dongle.
You will need an active internet connection though.
Old 12-06-2019, 09:22 PM
Oh ok great. Thanks for the info. So just to clarify, newer versions of Pro Tools did away with physical iloks and a "virtual license" will still work on more than one computer?
Old 12-07-2019, 12:12 AM
No. That’s not quite what I said.
One license only. But, you have the option to authorise to the iLok dongle or use the iLok cloud authorisation, which means you just log in so to speak when on a different machine that has a version of Pro Tools that allows cloud authorisation.
If you look it up all the info is there.
Old 12-07-2019, 09:26 AM
The Weed's Avatar
The Weed The Weed is offline
Or use one license and two iLoks and just use iLok's License Manager to move the licenses between the two iLoks. While you will need an Internet connection to do so, you won't need the Internet connection to be on all the time like you would with Cloud Authorization.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-07-2019, 02:50 PM
Yes I was going to suggest that too, but I thought if the OP found unplugging a USB dongle and inserting that into another machine tedious, then moving licenses around would probably be as much of a PITA.
You also have to remember to transfer the license cos if you forget, you’re screwed at the secondary location. Essentially no different than unplugging the physical dongle.
But it is another option for sure and it won’t require updating Pro Tools.
Multiple iLoks, Single PT License DelawareAve95 Getting Started 5 04-12-2014 03:00 PM
License across 2 iloks mark007 Pro Tools 10 3 01-05-2013 10:03 AM
1 PT9 CD.....2 iLoks? lucky666 Pro Tools 9 17 03-11-2011 07:26 PM
new iloks jafbox Pro Tools 9 0 11-08-2010 06:00 PM
two iLoks JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-17-2005 08:47 PM
