Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 12-15-2018, 08:33 PM
Macsearcher Macsearcher is offline
Default Slate Trigger crashing since 2018.12
Can anyone else who owns Slate Trigger confirm or deny this bug. I can't open any instances of this plug any more.
Old 12-16-2018, 12:23 AM
del cosmos del cosmos is offline
Default Re: Slate Trigger crashing since 2018.12
I’m having this problem too, but if I turn off my S6 Trigger works great.
Hope they (Avid or Slate) fix this soon.
Old 12-16-2018, 07:34 AM
clancychris clancychris is offline
I'm having no issues. I just tested it. using PT 2018.12 and Trigger ver 1.2.1
Old 12-16-2018, 11:46 AM
jjnssn jjnssn is offline
I just tried it and it is loading here. 10.14.2/2018.12. 1.2.1 also.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 12-16-2018, 03:21 PM
Just uninstalled and re-installed Trigger. Identical versions but for some reason it solved the problem for me.
Strange indeed.
Old 12-20-2018, 07:46 PM
fsavell fsavell is offline
I'm getting Slate Trigger 1.2.1 weirdness since upgrading to PT2018.12
It opens as normal but it doesn't recall the correct phase settings. It seems to load with all channels flipped. If I import plugin settings from the same session I just loaded, I can watch them flip back to the correct (saved) settings. Totally screws with my bottom end on kicks etc. Spent hours trying to solve why mix was lacking balls. Now i'm fearful of every mix I load will try reverting back to 2018.10, and hit up Slate support.
Forrester
Old 12-23-2018, 08:08 AM
Forrester
I had an issue where I was certain I'd checked phase on all my tracks, was having issues with something similar and found an instance of Trigger had a snare out of phase. I thought it was odd but figured I'd overlooked something. I'll check some other sessions and see if it's happened there also.
On a side note, your mixing and production is phenomenal.
Old 01-04-2019, 09:00 PM
aside aside is offline
I don't have the same issues as you guys, but Pro Tools now crashes occasionally whilst tweaking Trigger. Running 2018.12.
Old 07-05-2019, 08:30 AM
pasanta pasanta is offline
I tried an older version of trigger but that didn't fix the issues. So I went back to Eucon 3.7 and that cleared the problem up. But I also messaged Slate and they sent me a beta version r1.22. The beta does work with the most recent version of Eucon.
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 07:33 AM
S6 and Slate Trigger. del cosmos Avid S6 5 01-23-2018 09:16 AM
Slate trigger platnum & ex ? bonzerboy AAX Plug-ins 5 09-03-2016 08:24 PM
WTB: Slate Digital TRIGGER 2 EuroMix Buy & Sell 0 06-07-2015 08:49 AM
FYI - Slate Trigger EX jmitchell1532 Pro Tools 10 0 12-10-2012 09:55 AM
